585,982 active members*
4,644 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > NM-200 - strange behavior?
    Dec 2009
    594
    I was machining some blocks of grey cast iron this weekend, needing a profile.
    My first "attempt" was just to do a single cut with a 3/4' HSS 4 flute endmill, DOC=.200", radial cut ~.300". G-Wizard called 450 rpm, 4ipm.
    Well this was not a success, Once the endmill hit the material the whole machine started vibrating and the head got knocked out of tram along the x-axis. Time out to retram the head and snug down the bolts extra tight.
    Next try is with a 1/2" HSS endmill, DOC .100" full width cut. On the Bridgeport I run this at 700rpm and 5ipm and it cuts like butter. On the Novakon I get red sparks and the fluted melt off in 15 seconds.
    My conclusion here is that the RPMs don't seem to be accurate at low speeds, since it appears that the SFM is a lot higher than indicated by mach3. There's also a lot of vibration at lower speeds.
    I finally just used a 5/16" carbide at 4000 rpm, 10 ipm, which had no problems, although it took quite a bit longer.
    Jun 2007
    3891
    Quote Originally Posted by kvom View Post
    O_o
    was the spindle running the right direction? i ask cause i did this accidentally recently and had a similar result. vibrations, heat, but was still "cutting" so i was left scrathing my head until i actually saw the spindle wind down.
    on the nm200 ive done cast iron with a 1/2" carbide bit at 3500rpm and 20-30ipm and it cut like warm butter.
    Dec 2009
    594
    Spindle direction was correct. I think that the mill just doesn't like slow RPMs.
    I don't have any large carbide endmills; the 5/16 worked fine.
    Jun 2007
    3891
    i forget if yours is a series 1 or 2. ive run the 200 at 500rpm with a 7/8" cutter in steel and it was fine.
  1. Erratic motor behavior
    By KsiR in forum Stepper Motors / Drives
    Last Post: 06-03-2010, 09:15 PM
  2. Strange Behavior.
    By riveracnc in forum Mach Software (ArtSoft software)
    Last Post: 11-29-2008, 01:54 AM
  3. Milltronics strange behavior
    By KBHone in forum Milltronics
    Last Post: 12-10-2007, 12:00 AM
  4. Strange circle behavior, 151B control
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2007, 03:08 AM
  5. odd stepper behavior?
    By opusinwood in forum Stepper Motors / Drives
    Last Post: 07-05-2006, 01:30 PM
