Hello all. I decided to start a project log for my new mill conversion. I started out building the controller before I knew what I was putting it on, yes I do that a lot. I’m using a 24VDC, 6.5A power supply that powers 3 gecko G201 drivers and cooling with a 4" ac fan. As for motors I’m using automation directs 434oz-in Nema 34 steppers. .I am using mach 3 for control through a winford dbl25 breakout board. I’m getting excellent torque out of this setup with good motor speed. As for my mill I bought a Cummins mini mill. I just received the mill Monday and I’m finished to clean it up. My plans are for now to use the current lead screws until I build up some funds again for ballscrews plus that will give me the setup I need for the ballscrews. I also plan on installing a two speed belt drive and add a spindle lock in the near future. Any suggestions, questions, or complaints are welcome. Any thing you want to see more detailed just ask. I’m more that happy to help.
~Brad
