584,849 active members*
3,838 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 1050-3A M Code Board Compatibility
    Oct 2003
    530
    Quick question about the 1050-3A M code board. I'm using one in my vmc15 with a -4 system that I just sold. I'm replacing it with a 2001 vmc3016L with a -5 system. Will this board work in the -5 control?
    Thanks in advance :cheers:
    900
    Yes, the M function board will work with the dash 5 system with no problem.
    Neal
    Oct 2003
    530
    Thanks Neal!
    Btw, The 1060 motherboard on the new machine is different than the old machine. I don't see the terminal strips where I hooked up the wiring for my indexer on the old machine. Where do I hook up the wiring harness for my indexer on the new machine?
    Mar 2010
    motherboard
    The new style motherboards have a seperate board and ribbon cable to hookup the wires to.the ribbon cable plugs into the black connector on the center-right side that is inside the card cage.
  1. 64 bit compatibility?
    By Teyber12 in forum Uncategorised CAD Discussion
    Last Post: 06-29-2010, 12:07 AM
  2. GE 1050 control board parts
    By fxk3760 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-17-2009, 03:45 PM
  3. EMC2/ UbuntuCNC G-Code File format compatibility?
    By jneaimi in forum LinuxCNC (formerly EMC2)
    Last Post: 04-16-2009, 01:01 PM
  4. Replies: 3
    Last Post: 08-21-2007, 11:24 PM
  5. Compatibility
    By elogicca in forum Open Source Controller Boards
    Last Post: 06-09-2006, 10:34 PM
