Hey guys, I already post this problem in Mach3 forum, but no answer yet... I figure I might get more help here.
I have two computers
#1 (very old Dell)
450mhz CPU
500mb ram
64mb delicated graphix card
#2 (IMB think centre, just bought it from craiglist yesterday)
3.00ghz
1gb ram
128 Intel Share Chip graphic
I have been using the old computer to run test on my new CNC router, which have the Xylotex driver. Pretty much I left everything at Mach3 default and it work just fine. The funny thing is when I tried with the new computer... there's a problem. The setting on Mach3 are the same for both comp. IN the Motor Tuning window, the new one work too... I can jog back and forth at 2000mm/m just fine for all axis. But as soon as I EXIT that window and jog normally... every is mess up, stepper motor stall and run like a jig saw...and barely can travel at all.
To confirm this, I hook the driver back to the old comp (Dell) and as expected, it work just fine. What the hell right? So I change the Frequency to 35,000hz (IBM comp) and does not fix anything. So I took the IBM comp and plug it into my old Hubbard CNC Unipolar driver and... it seem to run it just fine.
WHAT THE HECK?
I have search all day and read somewhere someone said he was having a lot of trouble with his PC with a shared Graphic card?
Do you think this could be my problem?
