585,692 active members*
3,699 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Need more fonts in Edgecam.
Results 1 to 13 of 13
    Dec 2008
    441
    Red face Need more fonts in Edgecam.
    Hello, can i upgrade my "font store" in edgecam? where can i get fonts, and how do i import them in EC ?
    Greetings from Robert.
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    May 2008
    667
    Normally, you will look under free fonts on google.
    Put the fonts in the windows, Font folder with all other windows fonts.
    Normally, edgeCam will find them.
    Jeff
    Dec 2008
    441
    Ok.
    But i have many fonts in windows, but the Edgecam doesn have it.... Just 10 fonts or something in Edgecam...
    Do anybody try this site? 1001 Free Fonts - Download Free Fonts for Windows and Macintosh
    Robert.
    Dec 2008
    441
    Red face
    I copy all the fonts from windows to edgecam.. I can use them in edgecam, but i cant carve it out? i can`t mark it...
    Why?
    May 2008
    667
    I'm not an EdgeCam user but in the book I have about it it says.
    By default, the text is a bitmap text. When you choose the Burst outlines into curves button, the text will be converted to geometrical entities.
    And you need truetype font in order to use it for engraving.
    Jeff
    May 2008
    667
    Check this little tutorial about engraving in Edgecam
    Engraving - Graphics Software Tutorials Center
    Jeff
    Sep 2008
    24
    Vector use text cycles
    Truetype use slot
    If you use cycles pick a tool first
    Det ville være nemmere at hjælpe dig, hvis du vedhæftede de filer du har problemer med
    Jan 2011
    16
    loads of free fonts here (ttf), haven't tried them in edgecam yet
    http://www.webpagepublicity.com/free-fonts-v2.html
    Dec 2008
    441
    Hello again...
    I have tried and put the files in C: \ Program Files (x86) \ Planit \ Edgecam 2011 R1 \ Cam \ lib3dx \ intel_a \ Resources \ fonts
    and all subfolders, but they do not come up in edgecam.
    What do I do?
    Nov 2017
    Re: Need more fonts in Edgecam.
    Quote Originally Posted by Vegabond View Post
    Hello again...
    What do I do?
    Any update to this? I am trying to get more fonts in my "font store" and am having trouble (no response from Edgecam support ):
    Oct 2009
    47
    Quote Originally Posted by LabInstructor View Post
    When you create text (using the Text command), choose the TrueType option to use any TrueType font installed on the workstation. (See here for how to install fonts in Windows 10.) The text can be machined using any of the typical prismatic milling cycles.
    The Text command also allows Vector type text. The only text choices are the 12 installed with Edgecam, and this geometry is machined using the Text milling cycle.
    Customers needing precise design control over text often design in a CAD software tool, and bring it to CAM for machining.
    Nov 2017
    Quote Originally Posted by jsanders View Post
    Thanks JSanders! I should have provided more detail. I've installed my desired font (Windows 7), and it shows up in other applications, but not in Edgecam.
    Is there a directory in Edgecam that I need to also install the font? Is there a way to "refresh" so the font shows up (I've rebooted several times.)? Is there something weird about my font type (it's Open Type, but there are many other Open Type system fonts that show up)?
    I love the Project to Surface feature in Edgecam's engraving cycle, so prefer that to creating the text in CAD. I spent all day yesterday (unsuccessfully) trying to get equivalent results from NX Manufacturing.
    Nov 2017
    Solved (?)
    It worked after converting the Open Type font to True Type (installed in the Windows font directory). Still not sure why it worked, there are lots of Open Type fonts that do show up in Edgecam.
  1. Fonts another new subject
    By Gallchobhair in forum BobCad-Cam
    Last Post: 01-12-2014, 01:04 PM
  2. CHr fonts
    By adunor in forum NCPlot G-Code editor / backplotter
    Last Post: 02-06-2011, 03:50 PM
  3. Fonts
    By tjskcnc in forum Signmaking Topics
    Last Post: 01-12-2010, 10:48 PM
  4. engraving fonts
    By dpark1 in forum Mastercam
    Last Post: 10-19-2007, 03:30 PM
  5. Fonts
    By MPE racing in forum Uncategorised CAM Discussion
    Last Post: 07-03-2003, 04:19 PM
