I have a cnc4pc parallel port interface card and their mini power supply. I have taken a +5vdc from the mini power supply to the common terminal on the gecko.
I have no holding torque. In mach3 my motor just buzzes when I push the jog buttons. My steppers will not turn.
Here is another comment from a member from cnczone about my problem
Hmmm, I am still thinking it is the wiring rather than Mach3. I have just flicked through the gecko info and read this,
These inputs are optically isolated from the rest of the drive. Term. 10 is the common anode connection for the opto-isolators and must be connected to the +5 VDC supply of your indexer or pulse generator.
Since you are using a seperate PSU for the 5v, could it be that this is the problem? What you could try is to hook up the geckos using 5v from the PC instead, just to see if it makes a difference. Electronics really isn't my strong point though!
So where on the cnc4pc breakout board do I get a +5vdc source that also pulses. Where do I have to hook a wire from the breakout board to the gecko terminal#10 COMMON.
Peter
