585,886 active members*
6,218 visitors online*
Results 1 to 15 of 15
    Feb 2010
    22
    Fanuc OM 086 Alarm
    Hello,
    stopped after 4 weeks, I can not send more data is received at the PC or cable has been tested, all voltages are ok, and all other functions are ok. PC is changed, no change in Alarm.
    On what is this?
    Thank you for tips.
    Best Regards from Germany,
    Tom
    2932
    086 is DR SIGNAL DOWN. Check the resistance between pins 6, 8, and 20 on the CNC end of the cable. All 3 should be jumped together.
    Feb 2010
    22
    Hello,
    i checked the cable, 6,8, and 20 are jumped togehter. This Cable works last year...(and its fixed mounted)
    Greetings, Tom
    Feb 2010
    22
    Hi, perhaps a different solution:
    how can I activate the second, unused interface? M74 connector (instead of M5) on the Mem- board. The parameters 0002, 0038, 0050, 0552/0553, I've adjusted, however, the I / O port. No success, nothing, no Alarm. No function...
    Can i use this Port, the second interface? Or is unsuitable for PC connection and supports read-only devices as punchers and readers?
    Greetings,
    Tom
    (Excuse my bad english, ist comes from G....e)
    Dec 2003
    24221
    Send me a PM with email add I can send you the RS232 manual.
    Al.
    Albert E.
    Feb 2010
    22
    You have Post:wave:
    Greetings, Tom
    Apr 2009
    1379
    par 914 bit4 enables reader/puncher interface 2
    You may have to replace the 75188 or 75189 chips on the memory board.
    If you tell me the memory board part number I will tell you the locations.
    Feb 2010
    22
    Hello Memoryman,
    i have found the two 75188/89 on the Board. At first, i will check if interface 2 is possible to use.
    Many thanks for this Parameter, i had not seen yet.
    Greetings,
    Tom
    Feb 2010
    22
    after I had changed the parameters of 0914 / 4, a little bit of communication is there. My program says "Hardware detected a framing error" or "Hardware detect a parity error". Another software receives the data, but that's not the right format...
    Something does not seem to agree, data is being sent, but the PC shows only trash. 0002/0012/0038/0050/0553 and 0914 with parameters are all adjusted, 7 Bits,2 Stops, Even. Does anyone have any idea? Have i forgotton a parameter? It certainly seems as if broken, the first port, but what I must do in order to use the second port can?
    At the first port I had used the (easy) Three-wire communication cable, it may be that I need the second port of a more wires?
    Greetings,
    Tom
    Jan 2019
    33
    Thanks @memory man... i had the same problem for fanuc o md, following your instruction changed par 901 bit 6 for interface ...my problem solved....Really thankful...
    Jul 2018
    Hi memoryman
    Our fanuc O-M model have cnc. we can't send or receive this cnc from pc. he was working before. It's alarming 086. I checked the cable many times. I have also changed the parameter settings but the result has not changed. what kind of setting or cable connection should I use for this job using rs232? thank you in advance for help
  1. Fanuc 16M #445 alarm!!
    By fastolds in forum DNC Problems and Solutions
    Last Post: 06-09-2022, 03:58 AM
  2. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  3. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  4. Fanuc OMC 101 alarm
    By rai in forum Fanuc
    Last Post: 11-08-2010, 01:13 PM
  5. Fanuc 190 alarm
    By lmartin@oneal in forum Fanuc
    Last Post: 03-18-2010, 05:16 PM
