Hi all,
First of all, hello every one. I finally jumped in with an hybrid cnc which I should mainly use for woodworking, plexy and will probably do some alu eventually. The built is pretty much done with only the screws to install.
But in the mean while I started working on the electronic part this evening. So I plug my brand new S-350-24 power supply and I only get 14.78v to my surprize! 24v is supposed to be coming out.
Something like this: http://www.interinar.com/public_docs/S-350-24.pdf
I tried the voltage screw adjustment but nothing there. There is on the side the 220-115V switch which is on the correct 115v side. (not too sure what would happen if I try to move it to the 220v if somebody know...)
So I would like to know if someone has an idea, please say. Also I am not too sure if I can continue ahead with the wiring of my board with integrated drivers even if it is 14v?
Thanks for any advice.
Base
