585,702 active members*
4,185 visitors online*
IndustryArena Forum > CAM Software > CamBam > Arcs found when loading into cncwrapper
Results 1 to 2 of 2
    Jun 2011
    47
    I write a couple of words in cambam then load into cnc wrapper to wrap around a tube but I get the message "arcs found" and it wont load it. what are arcs and how can a fix the problem?
    Darren
    Feb 2005
    521
    I haven't used CNC wrapper myself, but it sounds like it cannot wrap arc gcode moves (G02,G03 codes).
    You can get around this by making CamBam convert arc moves to straight line moves (G01).
    In the latest CamBam version (0.9.8), you can set this in the post processor definitions. In here there is a property 'ArcOutput' which you can change to 'ConvertToLines'. There is an associated property 'ArcToLinesTolerance' which will determine how many line segments are used to replace the arcs.
    I hope this helps!
    www.cambam.co.uk
  1. New 4th Axis Software website, www.CNCWrapper.com
    By Reboot in forum News Announcements
    Last Post: 01-17-2012, 04:41 PM
  2. when loading my XML the arcs are messed up !!!
    By master_bebe in forum Mach Software (ArtSoft software)
    Last Post: 12-19-2010, 09:08 PM
  3. Incremental arcs and Break arcs into lines
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 09-16-2010, 04:55 PM
  4. arcs using I and J
    By MadPickinSkills in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-08-2009, 08:54 PM
  5. I and J 3D arcs
    By mmachining in forum BobCad-Cam
    Last Post: 02-14-2008, 08:01 PM
