585,581 active members*
3,841 visitors online*
Page 1 of 2 12
Results 1 to 20 of 31
    Feb 2010
    3447
    Touch probes 101!
    I would like to purchase a touch probe fairly soon for my cnc machine using mach 3.
    I found the "touch probe" plugin for mach below: It does state "may not work with newer versions of mach". I have the newest version..
    ArtSoft USA - Plugins
    So basically im asking who has a really good affordable touch probe that uses mach 3? Also what do you use to convert the points to a solid model.
    I have solidworks 2011, and access to solidcam and mastercam, along with cambam.
    I may need a short "101" intro on how this whole operation works.
    Deskcnc probe:
    Desk CNC from IMService
    cnc4pc.com probe:
    CNC4PC
    Shark Probe:
    CNC Shark Touch Probe - Rockler Woodworking Tools
    The shark probe is the most expensive but when used with there software it converts and smooths the entire model to a .stl and then claims it can immediately cut when it just probed. Sounds awesome but $600 for probe and software is $$$$.
    Anyways, let me know! I would like to be able to "reverse engineer" some parts and also use it to just setup up jigs, zero x,y,z on work pieces, etc.
    Feb 2010
    3447
    DeskCNC TP-100 Is roughly $325
    Probe - TP100 Probe
    cnc4pc.com probe $125
    CNC4PC
    Shark $299
    http://www.rockler.com/product.cfm?page=22582
    I could almost buy 3 of the cnc4pc probes for the price of one Tp-100, or shark. Same quality?
    Dec 2008
    15
    touch probe
    Quote Originally Posted by diyengineer View Post
    Deskcnc probe:
    cnc4pc.com probe:
    CNC4PC
    Shark Probe:
    you can find probes on e-bay for around 225.00 ea
    Dec 2008
    15
    Quote Originally Posted by broussard View Post
    you can find them at http://cgi.ebay.com/TOOL-PRESETTER-C...N-TOUCH-PROBE-
    Feb 2010
    3447
    Thank you! The link expired but i searched, tool setter and touch probe and found it.
    So @ $225 dollars what is the advantage of that unit compared to the the cnc4pc.com unit at almost half the price? Possibly a bit more quality materials, and engineering?
    May 2011
    You might look at this one. $125 + shipping.
    Vicrider
    Jun 2011
    692
    Assuming the DeskCNC and the Ebay are the same, or at least have interchangeable parts, getting replacement/different size probes for it should be easier than for the CNC4PC one.
    Plus, ruby tip is generally preferable.
    Feb 2010
    3447
    Quote Originally Posted by vicrider View Post
    Vicrider
    Vicrider,
    That probe is the same probe that cnc4pc.com retails.
    Feb 2010
    3447
    Quote Originally Posted by skrubol View Post
    Very true. Whats the deal with the ruby tip?
    Sep 2009
    1856
    Touch probes for sale
    [email protected]
    $125
    has any got one of these are they any good
    Feb 2010
    3447
    Quote Originally Posted by daniellyall View Post
    [email protected]
    $125
    I just purchased one, but from his retailer cnc4pc.com
    Havent used it yet, but its well made.
    Jul 2004
    595
    Check out the Tormach passive probe. I just purchased one and it's very good for the money IMHO. I have no affiliation but a happy customer
    David
    Feb 2010
    3447
    Quote Originally Posted by David Bord View Post
    David
    Dang! that is a really nice probe! I ended up going with the cnc4pc probe (glorified hobbyist probe that can produce great results with a smaller price tag). I will get comfortable with the probe operation (probably crash it a few times) since its pretty affordable i wont feel so bad. The tormach probe is on my wish list now!! Once i can handle normal probing operations ill get that beast. Looks really high quality.
    Any you tube videos using it? Also, i use mach 3. which are the best programs to use with it?
    Feb 2010
    3447
    http://www.cnczone.com/forums/genera...ml#post1121201
    I did get my touch probe functioning on a C32 Breakout board. reference link above if anyone else decides to go down this path with the same setup.
    Sep 2005
    171
    Email changed for my probe. Send me a private message.
    Or email me at [email protected]
    Dec 2007
    44
    tried to contact arnie but email bounced. do you have contact info? i am interested in probe. thanx
    He just posted a new email address on the Machsupport forum yesterday.
    Oct 2012
    9
    I'm about to purchase the same probe from cnc4pc, but want to use the sharkpro software to scan a part. has anyone purchased this software before and is it any good? I see it using the cut3d program, which I already have, and I check their website to see if it comes with a recording program, but it doesn't say anything about that just the cut3d program. if it is just that program how would I start scanning? thanks
    zerodegreec Guest
    FWIW I bought the CNC4PC probe. Was so bad that they sent me another one. This one is not much better. It cant hold its accuracy for more than 2 "tool" changes. The body and tip are not even close to being concentric on either of the ones I have in my shop right now. I am sending both back for a refund and am going to spend the money on the Tormach Passive Porbe
    Mar 2012
    77
    Quote Originally Posted by zerodegreec View Post
    Did you get the Tormach Passive Probe? Is it good? Thx.
Page 1 of 2 12
  1. Digitizing probes?
    By Shake & Bake in forum Australia, New Zealand Club House
    Last Post: 04-15-2011, 02:53 AM
  2. More Joys of Touch Probes
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 03-12-2009, 10:28 AM
  3. Mazak and Renishaw probes
    By sunfire03 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-29-2008, 09:37 PM
  4. A few ?'s about touch probes
    By maxboostbusa in forum Digitizing and Laser Digitizing
    Last Post: 12-19-2007, 05:55 AM
  5. Probes costs?
    By REVCAM_Bob in forum Uncategorised MetalWorking Machines
    Last Post: 05-06-2007, 03:15 PM
