I'm very much a beginner to CNC. I'm trying to build a machine that adheres photos to acrylic tiles. The system uses a stepper motor and ballscrew to provide the motion that moves the tile under the rubber laminator roller.
I've finally assembled all the components and am having a little trouble knowing which connection goes where. There are basically 4 components
1. 4200oz nema 42 stepper motor
2. DQ2722M Stepper motor driver
3. KTA-190 stepper motor controller
4. 24V Power Supply
The stepper motor driver has 240V input so no separate power supply is required. The 24V power supply is for the KTA-190 board. The KTA-190 is basically an interface between the serial port on a computer and the stepper motor driver. It allows commands in ASCII to be sent that create the pulses for the driver. There is more information about it here
Serial Stepper Motor Controller 12VDC :: Stepper :: Motor Controllers :: Ocean Controls
Note, I bought the 24V DC version.
My understanding is that I need to
1. Connect the 24V supply (V- V+) to the KTA-190
2. Connect the stepper motor to the B- B+ A- A+ on the driver
3. Connect 240V AC to the N L and Ground on the driver
4. Connect 240V AC to the N L and Ground on the 24V power supply
5. Somehow connect the PU+ PU- and DR+ and DR- to from the KTA-190 to the DQ2722M
I would really appreciate any specific guidance in this hookup.
Kind regards
Liam
