585,925 active members*
3,587 visitors online*
    Jun 2011
    802C-Please help me
    Dear Everybody
    I'm new working with SIEMENS SINUMERIK 802C.
    Can anybody help me how I can create "user-defined M function".
    Jan 2019
    4
    Re: 802C-Please help me
    hj Friend.
    Machine type defined by MD14510[16]. Lathe =0 (1) Milling =1 (2)
    2. Define traverse keys according to your machine tool
    MD14510[26] – X + key Lathe=23 (1) , (2)
    MD14510[27] – X – key Lathe=29 (1) , (2)
    MD14510[30] – Z + key Lathe=27 (1) , (2)
    MD14510[31] – Z –Key Lathe=25 (1) , (2)
    MD14510[28] – Y + key (if MD14510[16]=1) Milling = 24 (2)
    MD14510[29] – Y - key (if MD14510[16]=1) Milling = 28 (2)
    3. Define the inputs and outputs which are used as well as its wiring type (NO.NC) by
    MD14512[0]&[1] for inputs of DIO1 if all active = FF (1)
    MD14512[4]&[5] for outputs of DIO1 if all active = FF (1)
    4. Define the functions you need by MD14512[11]:
    Bit 7=1 Turret active for lathe
    Bit 6=1 Spindle gear stage change active for milling machine
    Bit 3=1 Spindle active
    Bit 2=1 Clamping/unclamping active
    Bit 1=1 Lubrication active
    Bit 0=1 Cooling active
    i think it's can help you.
    Thank
    Linh
  1. retrofitting with sinumerik 802c
    By is_razi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-17-2020, 09:34 AM
  2. Wait: For Spindle-802C
    By mabbasiazad in forum Want To Buy...Need help!
    Last Post: 06-08-2011, 07:37 AM
  3. Need Siemens 802C Controller Parts
    By LaysMachinist in forum SIEMENS -> GENERAL
    Last Post: 02-22-2011, 04:24 AM
  4. Isolate 0-10V? (Sinumerik 802C retrofit)
    By Jocke76 in forum SIEMENS -> GENERAL
    Last Post: 08-09-2010, 06:15 PM
  5. Siemens 802C
    By Htech in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2009, 11:57 PM
