I’ve been reading around these forums for a while now, and would like to venture into the world of designing and building my own 3 axis CNC machine.
I’m planning on using the machine mainly for aluminium milling but would like it to have the capability of machining steel. Now I know I’m pushing the boat out here for a DIY machine and that a machine capable of milling steel has to be very well designed and stiff, so I was hoping you may be able to help me.
IV sketched up a design on soildworks, and as it stands
it has a X travel of 1000mmY travel of 460mmZ travel of 110mm
The machine will mainly be comprised of aluminium and steel with some HDPE parts, its design and dimensions are built around the already machined ball screws available at ZAPP automation.
The X axis is comprised of a unsupported linear rail with angle irons on which V grove bearing will run across. I didn’t go for the traditional THK rails or supported rails due to their price, but feels as if the combination of both the unsupported linear rail and the angle iron will be adequate.
The Y axis runs on a set of 20mm unsupported rail, I know there has been hype on here that unsupported round rails are next to useless so I am weary that design will actually work. But the supported round rails seem so much more expensive. So my question would this work, if not would increasing the diameter of the rails to say 30mm help. Or is unsupported a complete No No.
The Z axis runs on a set of unsupported round rails of which are bolted to 5mm aluminium plate
The gantry is manly comprised of 5mm thick aluminium with an aluminium box section (2" by 1" and 1/8" thick) joining both sides (should i go which steel?). I’ve gone for 5mm to keep the costs down and think it should be adequate
Also does anyone know of any good and cheap suppliers of cnc stock such as suported rails and V groove bearings, im based in the UK.
Any help is much appreciated and thanks for looking!!
