584,842 active members*
4,423 visitors online*
Results 1 to 13 of 13
    Sep 2005
    Question heidenhain help
    can anybody tell me how to and is it possible to dripfeed long programs to a tnc151 control? :drowning:
    Nov 2004
    3028
    There is a BPT technical bulletin on communications to a TNC control. I have to find it.
    Just in case it exceeds the 500 KB limit here, what is your email?
    George
    Nov 2004
    3028
    I found technical bulletin 6. It is about 2.5 MB long.
    George
    Sep 2005
    thanx machintek.
    Nov 2004
    3028
    Done. See if this helps.
    Heidenhain can also be called. They are just outside of Chicago.
    George
    machintek
    Do you think I could get a copy of this bulletin also?
    Thanks Tony
    May 2004
    402
    Heidenhain Help: Dripfeeding TNC151
    Quote Originally Posted by DustyL
    Download TNC REMO from Heidenhain's site - set it up and run TNCSERVER
    Make up a cable from 25way TNC151B to 9 way PC as follows:
    (25way TNC) <9 way PC>
    (2) - <2>
    (3) - <3>
    (4) - <8>
    (5) - <7>
    (6) - <4>
    (7) - <5>
    (20) - <6>
    The TNC RS232 interface can exist in three modes - "EXT", "ME", and "FE" selected via the 'MOD' key - it should be in "FE"
    File names & extensions ARE important in block mode transmission. 123.H = program 123 in Heidenhain conversational code and 123.I is program 123 in ISO-Gcode
    When set up like the above it will work - it took me ages to sort it but now all is reliable.
    AWEM
    Andrew Mawson
    East Sussex, UK
    Nov 2004
    3028
    Tony, if you still need this tech bulletin, give me an email address.
    George
    machintek, sorry about that. It's [email protected]
    Aug 2005
    34
    George,
    Could you send me a copy of the tech note. Now that the mill is up and running it is time to get it connected.
    My e-mail is paul(dot)jeran(at)hp(dot)com
    Paul
    Nov 2004
    3028
    Tech Bulletin 6 sent to both of you.
    George
    Dec 2014
    5
    Re: heidenhain help
    Hi, where can I get that manual?
    Greetings
    Nov 2018
    Re: heidenhain help
    George,
    Do you still have this? Can you send it to me?
  1. Heidenhain 151
    By rmanning in forum Bridgeport / Hardinge Mills
    Last Post: 04-09-2010, 12:21 PM
  2. HEIDENHAIN TNC 145
    By zknives in forum Bridgeport / Hardinge Mills
    Last Post: 07-24-2008, 02:43 AM
  3. Heidenhain
    By bluedemon in forum Calibration / Measurement
    Last Post: 01-10-2008, 07:39 PM
