585,930 active members*
4,088 visitors online*
    Feb 2006
    120
    a benchtop CNC vertical mill
    hello all,
    I am currently engaged in a small benchtop CNC scratch build. I dont have time to do it, but I am making the time. hopefully this build blog will help me stay on track.
    and now a little about the project. this mill has a traditional vertical mill layout where the table has the ways on it and the slide does both x and y. the y ways are the base of the machine.
    I told my self that I would not spend very much on this project, we will see how that goes. so far it has cost me about $5.00.
    also I want percision, although I am less interested in speed, that is important too, I also want to make an ATC for it. hey a guy can dream cant he?
    at the moment the planned travals are:
    x 16"
    y 6"
    z 12"
    the table will be 6" x 24"
    I will most likely use steppers for the positioning.
    anyway. it is made of scrap that I had laying around from other projects. the mill is starting its life with cold rolled steel 1" x 2" haveing a track milled into is to acomadate the box slide. they are bolted to a 5" x 12" x 3/4" hot rolled plate. I am scraping them flat right now.
    Feb 2006
    120
    I have been working on the slide carriage; unfortunately I am battling serious square and parallel issues with the mill I am using. Oh well, I will just have to be more creative on setting up my work. Cast iron is a joy to machine, but even then I have managed to chip my second carbide cutter on it. My mill just sucks; hopefully when I am done this CNC mill will be way better.
    The bumpy road to get where I am going will just make my arrival that much more sweet!
  1. BenchTop Mill to Buy
    By leeschaumberg in forum Benchtop Machines
    Last Post: 04-10-2007, 10:57 PM
  2. Has anyone seen this benchtop mill before ?
    By jeff2005 in forum Benchtop Machines
    Last Post: 02-11-2007, 04:46 PM
  3. Not Exactly a Benchtop Mill
    By dcprecision in forum Benchtop Machines
    Last Post: 09-28-2006, 03:58 PM
