584,837 active members*
4,895 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Dewalt DWP611 1.25hp router $120 Lowes
Page 4 of 4 234
Results 61 to 77 of 77
  1. #61
    Aug 2009
    291
    Well, after all this time,... guess what showed up under the tree?
  2. #62
    Jan 2008
    241
    I've been using the bosh colt for just over a year now.
    Its been a great piece of kit!
    I think this will be my replacement unit when it does.
    but I do need the 1/8" collets. Any word on them yet?
    Cheers!
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
  3. #63
    Aug 2005
    437
    I’m also interested in a 1/8” collet as well. Anyone having luck at finding a source?
    Rob.
    Deeds not words...
    VoltsAndBolts runs RC for the builder. http://www.voltsandboltsonline.com/ My Forum
  4. #64
    May 2007
    86
    I did a search and came up with this item:
    STEWMAC.COM : Adapter Collet
    Its sitting here on my desk, haven't used it yet. I can't remember where I found it, but the user that recommended it was using it with this router.
    PiperPilot
  5. #65
    Dec 2008
    292
    I bought a couple of the StewMac adapters mentioned in last post and have been using them for about a month. They work great, seem to run true tho I admit I have not measured the runout yet. Think I will go do that right now.
    I have had no problems tho I was concerned about the brass deforming. However, I have cut aluminum with a 1/8" 2 flute end mill using these adapters and have had no problems.
    Don
    Update- I just went to the workshop and measured the runout with the StewMac 1/8" adapter. Measuring at what would be the end of the bit at approx 3/4" from the collet, I got .001 - .0015 TIR. If I rotated the adapter 90 or 180 degrees before retightening, the measurements were almost identical. For the work that I do, that is accurate enough.
  6. #66
    Apr 2009
    5516
    Amana also makes reducer bushings in different sizes, even metric. I bought a few a while back at toolstoday.com before I had the precisebits collets.
  7. #67
    Aug 2005
    437
    @ piperpilot. Thanks for the info I just ordered two collet adapters!
    @ atwooddon. Thanks for the quick review.
    Deeds not words...
  8. #68
    Jul 2006
    102
    Quote Originally Posted by sirkossorg View Post
    The original drawing is in Sketchup and was imported into Meshcam (you can see one of the raw pieces after cut in my thread in the GRZ software section). There's really not that much to the design. Are you looking for the Sketchup, Meshcam, or g-code file? The g-code is written for 1/2" stock, 1/8" bit, .05 per pass, 10ipm. Feel free to PM me.
    Has anyone posted their design for a mount for this router? I just ordered one and I'd like to start working on the mount. I guess I really only need to the diameter of the router to make a clamp.
    Just a general question, I never see anyone leave any router in default base and just use the mounting holes on the base. Is there a reason to clamp directly to the body of the router?
    -C
  9. #69
    Apr 2009
    5516
    I thought about getting another one... until I walked therough Home Depot a couple weeks ago and saw them blowing out the Bosch1617 for $159. With both fixed and plunge bases! The available PreciseBits collets for it was the deal-maker, don't know if Ron Reed has them for the DeWalt?
  10. #70
    Dec 2008
    292
    Quote Originally Posted by Miata2k View Post
    -C
    Here is a dfx of the DWP611 router mount I use on my machine. You are welcome to use it if it will help you. I use mine on a Fireball V90, you can adjust it to fit your mount requirements. It also has a standoff to support a vacuum tube. It takes 2 of this design to mount the DWP611 on my machine.
    Don
    Attached Files Attached Files
  11. #71
    Apr 2009
    5516
    -C
    There are some builds that do it; I know of one that used a 3-1/4HP plunge router (search haydn's excellent build on the forum.)
    Usually, the base protrudes a lot farther than would be desirable for mounting on the z carriage.
  12. #72
    Jan 2010
    6
    I am looking to build a mount for my fireball V90 for this router. Can someone tell me what material is reccomended? I am looking to make it out of plastic like HPDE or UHMW but not sure on the thickness, maybe 3/4 inch or 1/2 inch? Sorry if this has been posted before, but I have not been able to find a really good design.
  13. #73
    Dec 2008
    292
    monte9030
    HDPE or UHMW would work fine. MDF will also work. see post #70 of this thread. I used 3/4" MDF.
    Don
  14. #74
    Jul 2006
    102
    Quote Originally Posted by atwooddon View Post
    Don
    Don,
    Thanks for the post, since I'm still in the construction phase, I'm just going to use your drawing as a template and cut it out by hand.. I'm going to just leave off the vacuum port for now.
    -C
  15. #75
    Aug 2005
    437
    Here is a mount I whipped up. Feel free to modify to suit your needs. The clamp gap is sized to be cut with a 1/4" or smaller bit.
    Rob Wms
    Deeds not words...
  16. #76
    Dec 2008
    292
    I got tired of the downdraft from my DeWalt DWP611 spreading the dust before it could be picked up by the vacuum. The DWP611 is variable speed and has 2 LEDs in the base on either side of the spindle to light up the cut area which is very nice. I have used this router for about 40 hours now and it still runs like new. There didn't appear to be any easy way to mount the deflector to the bottom of the router until I noticed there were 2 screws that held the shaft lock button assembly in place. So, I designed an air deflector that would use those 2 screws as the attach point. All you need to do is find 2 matching screws that about 1/4" longer.
    It seems to work great, the chips and dust don't get blown around much at all making the vacuum pickup much more effective. Below are 2 pictures of the deflector right after cutting and 1 of it mounted. You can see the work surface below the router is well lit by the 2 LEDs. The only thing you have to do after machining is counter sink the 2 attach holes on the bottom with holes big enough to clear the screw heads.
    Don
    Attached Thumbnails Attached Thumbnails Deflector1.jpg   Deflector2.jpg   Deflector3.jpg
  17. #77
    Jan 2010
    6
    Finally got my Dewalt mounted on my V90! Here is a quick vid of it cutting out a better mount. This one is made with 3/4" plywood, 0.05" depth per cut at 15ipm with spindle speed of about 20,000rpm
Page 4 of 4 234
  1. Router Diemsions, hitachi, makita, dewalt, PC..
    By LazyMan in forum DIY CNC Router Table Machines
    Last Post: 09-30-2011, 06:46 PM
  2. Dewalt DWP611 and Porter Cable 450 "Compact" Routers + Questions
    By Scheer in forum DIY CNC Router Table Machines
    Last Post: 12-27-2010, 12:24 PM
  3. New DeWalt compact router DPW611
    By zool in forum DIY CNC Router Table Machines
    Last Post: 12-27-2010, 07:59 AM
  4. Collets for DeWalt Trim Router
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 05-22-2008, 06:55 PM
  5. Dewalt Router Experience Anyone?
    By boguski.1 in forum CNC Tooling
    Last Post: 04-30-2007, 08:25 PM
