585,578 active members*
4,079 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Telling tormach 1100 where the cutter is
    Jun 2011
    Hello,
    I am using a tormach 1100 with sprutcam. I cannot figure out how to tell the machine where my cutter is. and what depth it needs to be. I am 2d contouring a part in half inch plastic and basically want to set it up where i place the tool just above the plastic in the upper right hand cornerand have it cut the plastic from there. Just like the first part file from tormach. Thanks for your help i watched many videos and i guess i just dont understand.
    Zach
    Feb 2007
    1041
    Are you zeroing the axis out and referencing the mill before you start the file ?
    Jun 2007
    143
    When you CAM your part, you need to decide where the 0,0,0 location will be placed, in this case top right and I would guess, top of the stock you're cutting. Now that you have a reference point, Secure the stock on the machine, move the tool to that reference point you have marked on the stock using the jog feature. Once there, click the Zero X, Zero Y, and Zero Z buttons on the display. The buttons are located next to the x, y and z read outs. The CAM file and the machine now agree where 0,0,0 are and you should be able to machine the part.
    For 2 1/2 D I typically put the 0,0,0 at the top surface of the stock and in the center of the part, because it is easy to locate a rough center by drawing lines to opposite corners in a rectangle. This gives me the best chance of not hitting hold-downs and of fitting the job inside the stock.
    Feb 2006
    1072
    Zach, if your chosen starting point for the cutter is not X0Y0Z0 relative to the workpiece, you can also position the cutter where you want it, mouse-click on each DRO and enter the desired X, Y and Z coordinates defining its position.
    Randy
  1. Tormach 1100 software
    By remout in forum Tormach Personal CNC Mill
    Last Post: 05-13-2010, 07:32 PM
  2. TORMACH CNC PCNC 1100 only $6800.00 ???
    By twocik in forum Benchtop Machines
    Last Post: 08-21-2007, 08:26 PM
  3. How does Tormach 1100 Accuracy Compare?
    By sav1234 in forum Tormach Personal CNC Mill
    Last Post: 01-01-2007, 12:15 PM
