585,906 active members*
3,760 visitors online*
IndustryArena Forum > CAM Software > Mastercam > engraving letters on a diameter
    Sep 2010
    24
    Hi, can someone be nice enough to tell me how to translate letters on to a diameter. I've tried for weeks and the people I've asked either don't know how or they just don't want to tell me. I just took a Mastercam X4 class and the book does not show you how to do it, it just tells you to do it. I tried the translate command but it does it in a straight line instead of doing it at the same radius of the diameter. Any help will be verry much apreciated. Thank you.
    Jan 2008
    575
    I think I used "roll", but it was about 3 years ago, I could be wrong. BUMP
    Robert
    The beaten path, is exclusively for beaten men.
    Sep 2010
    24
    Thank you Rob, I tried it and was able to make the letters at a radius but not at the right position. I'll keep playing with it. Thank you for your time.
    Sep 2010
    24
    Hi Rob it's me again.I kept playing with your suggestion and got it to work the way I wanted. thank you again.
    Jun 2009
    65
    I am currently engraving some letters on our 4th in the Haas right now :-)
    Just in case your cutting expensive or one-off part; I had to roll my letters CW (backward in verify) to get what I wanted at the machine......
  1. Letters, Letters & Letters
    By Joe Crumley in forum Signmaking Topics
    Last Post: 11-20-2011, 03:46 AM
  2. Engraving Mirror Letters for Mold
    By Jilofalltrades in forum Fadal
    Last Post: 06-30-2009, 10:24 PM
  3. I need help engraving letters
    By cutter22 in forum Uncategorised CAD Discussion
    Last Post: 02-13-2009, 06:25 PM
  4. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  5. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
