We have an MX-55 with a U10M control. When using tool wear comp (programming to the tool center and using the the tool diameter to account for wear) the machine does nothing if the diameter is less then .010" or more than -.010". Supposedly we checked with Okuma and they said it is a known issue, but had no real solution other than programming things small and using a minimum D of .010"
Can anyone else confirm that they have this issue? Is there a software update available to fix this? What a PITA.
