585,975 active members*
4,922 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Predator CNC Editor - Backplot
Page 1 of 2 12
Results 1 to 20 of 30
    Apr 2011
    I thought I would try the CNC Editor, and selected it from BobCAD V24.
    It loaded the G-Code and also the stock dimensions, but did NOTHING when I started the backplot (it DID run through the G-code, but the model did not change).
    What am I missing? eg do I need to set up the machine type etc? If so, how would I select a 'Metric Mach3 with No Tool Change' machine type? I have the xml file from Mach3 (and BobCAD site), but do not understand what (and if), I am missing something to sdetup.
    Garry
    Dec 2008
    4548
    just after the editor loads and before you select backplot, select a 4XVMill which is located just above the code in your screengrab there and currently says "default".. It will then load with that machine file after that... After you choose Backplot and start it, you can right clcik in the backplot window and look at the properties.. Show tool, backplot... If it doesnt show anything after that, your post procewsor may need to be looked at.
    Apr 2011
    Still Does not Work
    I selected the 4AXVMILL and it did not make any difference.
    I did the right click and set the Show Tool Holder etc, looked at the parameters which had backplot ticked.
    No go.
    I am using the BobCAD supplied 'MACH 3 MILL NO ATC METRIC' post processor.
    The G-Code header is below. Has the stock dimensions and the tool parameters.
    (BEGIN PREDATOR NC HEADER)
    (MACH_FILE=3AXVMILL_MM.MCH)
    (MTOOL T1 S1 D12.7 H25. DIAM_OFFSET 1 = 6.35)
    (SBOX X0. Y0. Z0. L270. W620. H40.)
    (END PREDATOR NC HEADER)
    O100
    (PROGRAM NUMBER)
    (PROGRAM NAME - LEFT TOP COMPLETED 8A1.NC)
    (POST - MACH 3 MILL NO ATC METRIC)
    (DATE - SUN. 06/19/2011)
    (TIME - 08:56PM)
    N01 G21 G40 G49 G54 G80 G90 G91.1
    (JOB 1 SLICE CUT PLANAR)
    (FEATURE SLICE PLANAR)
    Mar 2010
    1852
    Just a thought, but select an iso view to make sure you are not viewing that back of the material. I have never seen a straight on view like you have displayed.
    Probably wrong, but worth a try.
    Mike
    Jun 2008
    1838
    Quote Originally Posted by aussiegazza View Post
    No go.
    O100
    (PROGRAM NUMBER)
    (TIME - 08:56PM)
    Burrman said to select the 4XVMILL template, the second line down in your header must match the machine file you select in that box.
    You have this :-
    You should have this :-
    (MACH_FILE=4AXVMILL.MCH)
    They will now be matched, if you want to keep the header as it was then just select the "3AXVMILL_MM" template.
    Regards
    Rob
    :rainfro::rainfro::rainfro:
    Apr 2011
    Quote Originally Posted by The Engine Guy View Post
    You have this :-
    Regards
    Rob
    There is no "3AXVMILL_MM" template option. Only non-metric generic templates or model specific template.
    I tried all of the metric template options and no success.
    The 'MACH_FILE' setting comes from my post processor. I do not want to change the post processor.....
    I think I need to find an equivalent CNC Editor 'template' that understands the G-code formats that my post processor generates.
    I will look at the download options or update options on the BobCAD website. Then I may request a template be created....
    Jun 2008
    1838
    It is easy to change the Post Processor to output a different named Machine File, I have a few that I named to suit the actual machines I use in the shop.
    For example I have an old Bridgeport 412 VMC and I simply copied a template and saved it out under the name "BRIDGEPORT_412".
    I have attached the Template and it`s associated Reverse Post file in a Zip file for you.
    Open the Zip and simply copy and paste the files into the following folders:-
    The Machine file goes in the C:\Program Files\Predator Software\Common Files\Machines folder on your PC.
    The Reverse Post file goes in the C:\Program Files\Predator Software\Common Files\RPost 7.0\Mill folder on your PC
    Once you have the Machine file in the folder just navigate to the file and right click and then select "re-name" and make the name of the file EXACTLY the same as the Machine file line in your header, eg 3AXVMILL_MM, then when you open the Predator Editor 2 you should be able to go to the drop down list and find the 3AXVMILL_MM listed there.
    With a bit of luck that should work for you, it works fine here With a bit more luck you may find that from then on whenever you open the Predator Editor it will default to that template for you
    Regards
    Rob
    Attached Files Attached Files
    Apr 2011
    Regards
    Rob
    Tried that and found that it did not appear in the list of templates. I needed to create a new Access Database and add it in. Given I am a ICT PM, I knew how to do this. Then could select it. No help.
    Decided to rename a metric template in the folder to my 3axvmill_mm name.
    Backplot did exactly the same thing. I have got this far previously by selecting a metric template in the list. I do not therefore think that the template name needs to be the same as my post processor name.
    Very frustrating!
    Thanks all for your help BTW. Very supportive site.
    Garry
    Dec 2008
    4548
    I think the post is not setup correctly.. If you attach it here we can look at it.
    Apr 2011
    Quote Originally Posted by BurrMan View Post
    I raised a job with BobCAD support and they sent a new pp and it did not work either. They also had me check that the Project directory setting was correct (it was). Also had me check that the Virtual CNC ran correctly (it did, but I am using the CNC Editor to backplot - they could be related though).
    Only issue I can see is my PC is 64 bit and the Project directory points to an x86 Program fiolder and the Predator code is 32 bit.
    I have sent a screen shot and the gcode to them. Could it be related to video card?
    I will keep you all updated.
    Garry
    Jun 2008
    1838
    Garry
    Just to test my own theory I cleared out the Machine File folder and the Reverse Post folder in a Predator installation on an old Laptop that has V23 on it.
    First I created a new template named BRIDGEPORT_412 and then I was able to copy the BRIDGEPORT_412 machine file downloaded from the "Zone" into the folder and save it to the folder and let it overwrite the existing file of the same name. That gets it into the folder so it can be "seen" and selected.
    Then I copied the Reverse post file to it`s correct folder and then ran V23 to create some code, opened Predator from V23 using right click and "Edit NC".
    Predator opened, I selected the BRIDGEPORT_412 machine and checked it was using the Fanuc 0 reverse post and ran the simulation no problem.
    Give that method a try, you do have to have the machine file name in line 2 of your header the same name as the machine file template you want to use, they have to match, also the control type needs to be one that will run your code correctly, Mach3 pretty much uses Fanuc0 from what I`ve seen ! !
    Regards
    Rob
    Apr 2011
    Garry
    Regards
    Rob
    Thanks for the help Rob.
    This is the response I got from BobCad Support:
    This is in reference with your Request Ticket Number: BS00038599.
    The template doesn't necessarily have to reflect the name of your control. You may create a new template with your machine name if you wish and set it to metric. IF you use one of the templates that are set for mm such as haas for instance and use the Post that I am attaching it will backplot. If you are trying to backplot and it is not working it is more than likely that your post is missing information. At the beginning of the Program it needs to see "(BEGIN PREDATOR NC HEADER)" and then have the information for tool and stock definition.
    I have attached a copy of the post processor I created for you in a zip folder. If you save the attachment to your desktop,open and copy. Go to your hard drive, C :/ Bobcad Cam Data/ V24/Posts/ Mill and paste your pp in this folder.
    If the simulation will not work there a couple of things that may cause this follow the instructions below to trouble shoot the problem.
    1. The simulation or project directory is improperly set
    To resolve this click on Preferences then Settings Default choose Directories and make sure the path is set to
    C:Program FilesPredator SoftwareCommon FilesJobs
    2. The virtual cnc is improperly installed or not installed at all
    To resolve this, open windows explorer and navigate to
    C:BobCAD-CAM DataBobCAD-CAM V24System Files
    Or
    C:Program Files (x86)BobCAD-CAMBobCAD-CAM V23System Files
    Run the Predator Virtual CNC 2007 for BobCAD.msi file by double clicking it.
    Please reply back to this email without changing the subject line if you have further clarifications.
    I have the Predator Header in the Gcode.
    The rest of the GCode is simple coordinate moves.
    I have got a good metric template and also a good controller (which I really don't think makes a difference, as I do not want/need to connect to, or simulate a genuine CNC interface.
    I am at a loss. The G-code works on my CNC. All I can think of is a hardware problem eg video card, or a 32 bit versus 64 bit OS issue.
    Anyway, we will see what BobCAD says.
    Jun 2008
    1838
    Hi Garry
    Hmmm, not sure what BC are saying there, the "Control" must be one that is capable of reading correctly the code you are trying to backplot.
    Way I look at it is basically the same Post Processor in reverse, for example if I generate code for a Hurco CNC and then try to use a Fanuc based reverse post it isn`t going to work so to me it has to match up.
    Attached are a some images that show how things are called, the machine file ( The BRIDGEPORT_412.MCH in my example) calls up the reverse post (The .RPM file, FANUC0 in this case).
    If you have got to the stage of seeing the stock but no tools when the code runs then it may be your Post doesn`t have the correct setup.
    Try opening your Post in Notepad and checking lines 108, 109 and 110 in your Post, should look something like this but without any spaces, I am just going to copy and paste the lines from my Post that I know works but the Forum software sometimes puts spaces in where they shouldn`t be and Burrman did tell me once how to overcome that but I`ve forgotten So if you do paste it into your own post make sure there are no spaces
    Anyway, here are the three lines from my post:-
    108. Rectangular stock format.
    comment_start,"SBOX X",stock_min_x," Y",stock_min_y," Z",stock_min_z," L",stock_length," W",stock_width, " H",stock_height,comment_end
    109. Rotary stock format.
    comment_start,"SCYL",rotation_axis,"X0","Y0","Z0", rotary_stock_diameter,rotary_stock_length,comment_ end
    110. Tool list format.
    comment_start,"MTOOL","T",list_tool_number,mtool_t ype,"D",tool_diameter,"H",tool_length,mtool_angle, mtool_corner_rad,"DIAM_OFFSET ",list_tool_number,"= ",tool_radius,comment_end
    Here are the images :-
Name:	Reverse Post File.jpg
    Don`t know if it will help, it`s all I`ve got right now, if the the files I posted for you don`t work in your PC then maybe BC are correct in that you have a possible corrupted installation of the Predator software ! !
    Oh BTW don`t worry about the lines in my header with the SSTL and FSTL in them, they are just for calling up STL solids of already machined shaped stock, vices and clamps etc for a more realistic simulation of what will actually be on the machine table
    Regards
    Rob
    Dec 2008
    4548
    Hey General,
    It's the "CODE" button on the forum post edit toolbar.. It looks like a pound sign or a hash... Next to the quote/link/attach buttons and such...
    Apr 2011
    All Predator SW is Properly Installed.
    I can run both the Virtual CNC and the Editor.
    They are properly installed.
    I have sent the G-Code NC file to BC and I hope they can work it out.
    I am paying for support, so I get post processor support. I am hoping they can send me compatable config files.
    I have got 'Verify' to work under V24 by setting the speed to FAST. Does not work at any other setting.
    I really do not have a need for the editor or virtual machine, other than I want to do a backplot to check the G code.
    My Predator Header says:
    (MTOOL T1 S1 D12.7 H25. DIAM_OFFSET 1 = 6.35) <-- The tool
    (SBOX X0. Y0. Z0. L270. W150. H40.) <--The Stock Dimensions
    Garry
    Jun 2008
    1838
    Hey General,
    Hi Burr
    Thanks, knew you`d be watching in the background somewhere
    Hmmm, "hash" sign I understand, pound sign to me is one of these "£", usually associated with someone demanding money from me, I prefer the black ones but don`t see many in these dark times
    Regards
    Rob
    Dec 2008
    4548
    Hi Burr
    Hahahaaaa. I was thinking of that when writing it!!! Does your "phone" have one on it?? And if it does, what does the automated phone voice say when you are supposed to hit it???
    And if you said "Hash" to me, I would ask "who's got matches!!""""
    Apr 2008
    1577
    I noticed in your first post that you are running subprograms. I have no trouble (I think, I rarely use subs) with the GCode at my machine but I haven't had any luck getting a program with subs to backplot correctly in Predator.
    What usually happens is that the moment the Editor hits an M30, it stops backplotting. EDIT*** It may also stop at the M02 depending on the reverse post-template you are using. You'll have to open it up to take a look.*** I tried reconfiguring my post to make sure the main program is at the bottom and post the subs first, but still Predator doesn't seem to make the jump to the subs properly. If you can figure this out, my hats off to you because it had me stumped.
    Apr 2008
    1577
    Got some right here for you bro!
    (flame2)
    Apr 2008
    1577
    "M30" : ProgramEnd
    This is the line in MY reverse post that marks the end of the program. Multiple definitions are supported so there may be something like this in there (from the Reverse Post Manual):
    ProgramEnd
    Description: Maps end of program
    Tech Tips: Selects the end of the CNC program or file. On most CNC controls this is
    a M2 or M30. Examples using this function keyword include the following:
    “M2” : ProgramEnd ; Fanuc style
    “M02” : ProgramEnd ; Multiple definitions are supported
    “M30” : ProgramEnd
    There is a tiny note, almost an afterthought, at the end of the manual that remarks:
    ; Note ProgramEnd causes
    ; scanning to stop
    I don't know if this will help you at all but I think this may be where the root of the problem lies. Good luck and I will try my best to help.
Page 1 of 2 12
  1. Where is the licensing for Predator Editor at?
    By Stampede in forum BobCad-Cam
    Last Post: 10-12-2015, 03:15 AM
  2. Predator CNC Editor backplot issues
    By petek in forum BobCad-Cam
    Last Post: 04-03-2011, 08:32 PM
  3. Predator Backplot
    By bret4 in forum BobCad-Cam
    Last Post: 01-25-2010, 03:22 AM
  4. Predator Editor problems
    By tntmfg in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-25-2009, 06:24 PM
  5. Just Purchased Predator Editor Level 2!!!
    By tobyaxis in forum BobCad-Cam
    Last Post: 08-08-2007, 11:21 PM
