585,886 active members*
5,848 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Nov 2009
    4415
    Re: DM 2400 refit.
    The oiling system is pretty elaborate too.
    A lazy man does it twice.
  2. #22
    Nov 2009
    4415
    Re: DM 2400 refit.
    Check out the attention to detail on the column bolts.
    Attachment 292288
    This machine has a work envelope around 4"x4". Weighs about 200lbs. Quite different than say a Sherline.
  3. #23
    Nov 2009
    4415
    Re: DM 2400 refit.
    Gib strip adjusters and locks.
  4. #24
    Nov 2009
    4415
    Re: DM 2400 refit.
    X & Y axis have rubber bellows covering the lead screws. Nice little flanges they attach to also.
  5. #25
    Nov 2009
    4415
    Re: DM 2400 refit.
    Here is the nut assembly.
ID:	292648Click image for larger version.
  6. #26
    Nov 2009
    4415
    Re: DM 2400 refit.
    Quote Originally Posted by Fastest1 View Post
    I believe I want to put this machine up for sale.
    It is not operational at the moment as I was about to remove the gear reductions. I have the Griftek stepper mounts that allow that conversion, a few of the Dyna tool holders and many assorted bits. Look thru this thread as there are a few mods ;-) A full enclosure with a chip auger. It was never completed but I do have the chute and auger. I will not separate the parts. I will work on getting some recent photos as it is buried in the garage. I am also considering selling the DM3000 with all of its bits. Preferably as person willing to pick it up in the Houston area. Too many parts to list.
Page 2 of 2 12
  1. bridgeport refit
    By southozzie in forum Vertical Mill, Lathe Project Log
    Last Post: 05-20-2013, 12:30 PM
  2. Old Techno 4x4 repair/refit
    By luv2bsailin in forum Techno CNC
    Last Post: 10-28-2011, 02:28 PM
  3. Connectors for CNC Mill Refit
    By Bruce Griffing in forum CNC Machine Related Electronics
    Last Post: 04-07-2009, 08:52 PM
  4. Starting a Test Refit
    By pauldkeeton in forum LinuxCNC (formerly EMC2)
    Last Post: 10-20-2007, 03:37 AM
  5. Setup Help, CNC refit
    By FBJR in forum MetalWork Discussion
    Last Post: 08-11-2007, 06:27 PM
