Originally Posted by
Rodney Gold
Check the parameters like speed and power of the file you are sending is correct and they the item is being output
If you have a laser button on the machine control panel that allows firing independantly of the computer and this doesnt work then:
check the water flow sensor if you have one
check any safety interlock switches (like the aforementioned door switch)
Check the power supply fuse is still ok (inside the powersupply box) ,if the powersuppy box has a fan and its not working , then the fuse is probably blown
check the power supply is working and hasnt popped a component
check the tube and all wiring to it
Check the motherboard wiring to the laser
If you can actualy see the tube fire inside the tube but get no output at the laser head , check the optic path
