I have Hurco KM3P with Electrocraft servos. Y & Z axis have belts & pulleys from the motors to the ball screws.
The X axis is direct drive. There is a strange coupling attaching the motor to the ball screw.
Do I just remove the set screw that I have marked in the picture?
Then remove the (4) bolts attaching the motor adapter to the table?
This is where the coupling is located in case anyone was wondering.
My guess is that it is set-up for misalignment & probably absorbs vibration and shock to keep from transmitting problems to the ball screw bearings.
I Just want to make sure that this isn't one of those things, that when you undo it , springs & stuff fly everywhere.(chair)(chair)(nuts):nono:
Thanks in advance,
JAckal
