Greets,
My company produces monitoring equipment for solar power systems. While my background includes enough different engineering skills to draft a part, I've never created a DXF file for a Flow jet.
The DXF file my sheet metal vendor gave me back shows lines and arcs for cutting and traversing. Am I correct in assuming that so long as I connect all the cuts and traverses that the program will run correctly? The issue I have is that I modified the part so that the first circular cut, which was on the edge of the part, is no longer followed by traverse to the next circular cut. So I don't know how to reconnect everything and their turnaround on converting my part to a DXF file is longer than I have patience for ...
