585,663 active members*
3,056 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > NEED BRIDGEPORT SERIES ONE EZ TRAK WIRING DIAGRAM
Results 1 to 10 of 10
    Feb 2006
    57
    I PLUGGED IN THE SERIAL CABLE FROM THE EZTRAK CONTROLLER TO THE MAIN BOX AND SOMETHING BLEW. MADE A LOUD BANG. NOW I HAVE NO IDEA HOW TO FIX IT THE FUSE THAT BLEW JUST KEEPS BLOWING.
    ANY IDEAS
    THANKS
    Oct 2003
    45
    Korellibopper
    This should be what you are looking for.
    Del
    Attached Files Attached Files
    Feb 2006
    57
    Talking
    ill show the electrician it looks grat to me though thanks a million
    Aug 2009
    65
    I f those prints don't match let us know. There were a number of different versions of the EZtrack control wired by a number of different companies for bridgeport...all of them had different prints. Does the machine have a facotry flatpanel lcd monitor (not an aftermarket one)? Where is the floppy drive located on the machine?
    Feb 2006
    57
    the machine is a Bridgeport Rapid 8 model.
    Aug 2009
    65
    Quote Originally Posted by Korellibopper View Post
    No rapid 8 is the power drawbar. If the ez trak prints that were posted do not match your mill you will have to help identify which version of eztrak you have. Rather than going off on a tangent it would be easier if you tried to answer the questions I asked in the last post. The other option is to forget abouthaving an electrician look at it and call in a cnc technician who is familiar with eztraks and likely has the prints already.
    Feb 2006
    57
    Its been fixed the lube pump was causing the fault. To answer your questions there is no lcd or floppy drive on this machine. the only label is ez-trak on the control box. This machine is about 27 years old.
    Feb 2010
    Question
    Do these apply to an EZ-Trak DX 2000 with 3-axis? Also, do you have access to a service manual for this model? thanks.
    Nov 2004
    3028
    Probably a EZTRAK by Southwestern industries.
    George
    Feb 2010
    Where would I be able to find a service manual for a Bridgeport EZ-Trak DX (built in 2000)?
  1. Series 1 Wiring diagram
    By TarHeelTom in forum Bridgeport / Hardinge Mills
    Last Post: 09-06-2011, 06:00 AM
  2. 1997 Bridgeport EZ-TRAK SERIES 1 DX
    By tdr1985 in forum Bridgeport / Hardinge Mills
    Last Post: 10-22-2010, 03:43 PM
  3. Serial wiring for Bridgeport EZ TRAK SX
    By brussell in forum Controller & Computer Solutions
    Last Post: 01-09-2009, 08:33 PM
  4. Bridgeport Retrofit Wiring Diagram
    By UKRobotics in forum CNC Machine Related Electronics
    Last Post: 09-18-2006, 10:39 AM
  5. system Wiring diagram, BMI Trak W/LCD needed
    By bsllc in forum Bridgeport / Hardinge Mills
    Last Post: 02-17-2006, 10:18 PM
