585,589 active members*
3,754 visitors online*
    Jul 2011
    citizen l20 type 9
    I am doing a 3.5" deep hole in 5/8" copper. When i go to od turn The barloader is alarming out ($5 overload). Is my tourqe setting too high? I can not figure it out and the material is very pricey.
    Jul 2011
    on the last few pecks the machine is making a wierd noise.
    Oct 2008
    108
    Are you using coolant through drills? It sioounds to me like you might be pushing the material back with the drill and causing an A7 overload, especially if its making a strange noise the last two pecks.
    www.atmswiss.com
    Jul 2011
    Figured it out. I did a g83 to 3" then for the rest i did a feed in feed out. Thanks though
  1. CITIZEN L20 TYPE 8
    By chet470 in forum CNC Swiss Screw Machines
    Last Post: 07-01-2011, 04:04 AM
  2. Citizen A20 Type 6 or 7 ??
    By will1717 in forum CNC Swiss Screw Machines
    Last Post: 01-26-2011, 07:09 PM
  3. G71/G72 type I vs. type II cycles
    By sinha_nsit in forum Fanuc
    Last Post: 08-28-2010, 11:20 AM
  4. Citizen L25
    By appusivadas in forum CNC Swiss Screw Machines
    Last Post: 07-16-2009, 02:51 PM
  5. G71 type I and type II cycles
    Last Post: 11-03-2008, 12:34 PM
