Hi everyone,
I need help on a project to output XYZ coordinates from Solidworks for a tube design. Similar to an exhaust pipe where it is bent in space if you will not just in XY plane. Tube Mfg. is requesting this, to be able to bend tube in CNC Bender.
Example: Mgr needs the start point of arc and end point with Arc center for radius. The tube centerline is made up of 2 sketches but joined with using a composite curve. I tried to use ordinate method but does not output for a composite curve.Honestly not sure wher to go with this. Any help will be appreciated. Thanks..
See attached file-using Solidworks 2010..
JC
