585,766 active members*
4,548 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Advice Needed on Software
    Jun 2011
    I am new to CNC so I can't tell you what I don't know. I am building a 25"x25" cnc router table based on the Solsylva plans. I am ready to buy drives/motors/software. I found the following package on ebay: Gecko G540 3 Nema23 Steppers 300 oz/in Mach3 Bobcad V21 | eBay
    I currently have access to Autocad and Alibre Pro that I could use for drawing. My thought is that v21 of BobCad is bundled with the ebay kit and could be used for generating gcode after I make my drawings in Autocad or Alibre.
    Please consider the first 5 words of the post and offer any advice you may have..
    Thanks in advance,
    Brent
    Mar 2010
    1852
    You should be able to import your drawing files into BobCAD and generate code. Of course you can also draw in BobCAD. V21 is pretty easy to draw in and since you will be working in 2d, you should have no problems.
    Mike
  1. Advice needed
    By kiramunch@sympa in forum Glass, Plastic and Stone
    Last Post: 06-25-2011, 09:03 PM
  2. Need software advice...What software can import .JPG files?
    By pairofjacks in forum Uncategorised CAM Discussion
    Last Post: 06-01-2011, 12:18 PM
  3. Advice needed.
    By chipslinger69 in forum Benchtop Machines
    Last Post: 12-13-2010, 03:25 AM
  4. Advice needed.
    By Terence E in forum Community Club House
    Last Post: 05-14-2009, 03:56 PM
  5. advice needed / to buy or not???
    By teamjnz in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2008, 02:48 PM
