585,926 active members*
3,780 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Issue with G71 and Taper angle
Results 1 to 13 of 13
    Apr 2010
    260
    I am trying to create a 3/8 NPT. here is the code for the event
    G01X.636F0.0556
    G71X.5788Z-.2735A178.201H.0481D.02U.02B60F.056J18
    When I use this I get an Error Code 2254
    If I input A as 1.7988 the cycle runs but the taper is inward
    What am I doing wrong here
    thanks
    www.machmachine.com
    Apr 2009
    1262
    I typically is an I value rather than an A. Have you tried a negative A value with the small angle?
    I think your A178 is too large according to the error message.
    Best regards,
    Jan 2008
    575
    I agree, I never use the A value, I always use I, it's much simpler, less trig. is always better in my book.
    Robert
    The beaten path, is exclusively for beaten men.
    Apr 2006
    822
    The whole point of using the A value is that you can easily enter the taper angle for the desired thread.
    i.e 1.798 for BSPT threads.
    The idea behind the I value is for taper correction.
    You are probably just entering the angle improperly. A178.2 is totally incorrect.
    A1.798 should be correct.
    Jan 2008
    575
    Quote Originally Posted by broby View Post
    Yeah but who the hell uses bspt threads, freakin' Aussies.
    I cut a few different angles on threads so I like the I value. But like I said before I never use the A, does it cut the right thread angle regardless of lenght of engagement or start points or whatever?
    Robert
    Apr 2006
    822
    Quote Originally Posted by littlerob View Post
    Robert
    haha up yours Rob!
    Well Rob, we actually use BSPT and NPT threads fairly often.
    Could also be used for API threads, but that is a Licensed thread form I think...?
    haha just goes to show ho dumb you damn yanks are...!
    Yes the taper angle stays consistent over whatever length that you specify, or whether you change the start point on X.
    Cheers to you, you dumb bum!
    hahahahhahahahahahhaa
    Brian.
    Jul 2005
    380
    I've never used the "A" function in a thread cycle, only the "I" factor. I do know that for "A" - it's degrees specified from 3 O'clock, at least on my OSP5000. So a 178 in "A" would be nearly 180 degrees from 3 O'Clock.
    Jan 2008
    575
    haha up yours Rob!
    Brian.
    Oh nice, the hits keep coming. I cut ALOT of API threads, I don't know about any license agreement. Easy enough though. I may try using the A value though, it seems like there was something that turned me off about using it, I just can't remeber what it was.
    Dec 2008
    3109
    You 2 are worse than the kids in the back seat
    "are we there yet ?",
    " how long now ? "
    Rob(wedge):argue::stickpokeBrian
    :tired: :tired:
    Apr 2006
    822
    Was probably your dumb brain being unable to understand the command!
    BTW He started it first!
    He poked me!!
    Are we there yet?
    Jan 2008
    575
    Nov 2012
    6
    Quote Originally Posted by dingo0722 View Post
    G01X.636F0.0556
    thanks
    Did you find out solution
    Jun 2015
    4154
    Re: Issue with G71 and Taper angle
    hi Chispas, i don't have time now to test the original code ... please, what exactly do you wish ?
    yup, indeed, A value is pretty expressive to input the desired angle, and it remains the same, regardless of threading travel, that may change when clearances are shifted
    trigonometry has some simetry among the quadrants, so check this code, with a simplified value for the A argument; ups, i just saw that also mr wizard sugested this at #2 / kindly
    Code:
        G50 S2000
        G00 X500 Z250
        T101
        G97 S1234 M42 (M08) M03
        G00 X50 Z5
        G33 X40 Z-35 F0.75 G95 A-2
        G00 X500 Z250 T100
        M02
         A           X for thread end
        178 or -2     42.793
        182 or  2     37.207
      checking : [ 42.793 + 37.207 ] / 2 = 40 : same as G33 X40
                    2.793 / 2 = 1.3965        : same as attached
  1. Taper mill angle
    By claudiu220405 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-23-2013, 04:46 PM
  2. Taper angle on ER collet?
    By Jonne in forum MetalWork Discussion
    Last Post: 08-02-2012, 12:51 PM
  3. Difference in Female Taper angle using Taper Cutter
    By Buntron in forum Material Machining Solutions
    Last Post: 06-07-2011, 06:53 AM
  4. help with cutting a inverse taper angle
    By redfoxbody11 in forum Uncategorised MetalWorking Machines
    Last Post: 11-12-2010, 01:10 PM
  5. Fanuc servo shaft taper angle?
    By Jonne in forum Fanuc
    Last Post: 03-28-2008, 05:58 PM
