I'm in trouble with a PUMA230 Servotorret, managed with a promotion servo. Did any body has the manual to setup it properly?, the main problem is the costumer lose the parameters due battery off.
A full manual in pdf should be very appreciated
generally when the battery goes dead you do not lose the parameters from the promotion drive.
All you need to do is home the turret.
Parameter 8 should = the current station
there are a couple of other buttons you will need to push to finish the homing procedure.
The 'Blue Book' that comes with the machine contains a procedure and a complete list of parameters for that promotion/motor combination
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
Thans' MistyMonkey,
Thats' what I made but I have some problems always on the same station, didn't clamp correctly, I home the turret at station 8 and I always have problems of clamping turret at station 2, when I changed the homing turret at station1 the problem pass to station 7. I solving doing something I didn't know, the procedure was like restart data offset or somethink like this. That's the reason I want a manual, to understand what I made.
get in touch with [email protected]
they can help you with manual
