585,779 active members*
4,018 visitors online*
    Jul 2011
    In need of machine setup/wiring help
    I just purchased a ez-router plasma 4x8 table used and a new thermal dynamics A40 plasma. I don't know how and where to connect the plasma to the cnc table. With the table I also got the thc1000 (torch height control). My new plasma has 4 outputs (on/off, and I believe height values) Can anyone help with where to wire these 4 wires. any wiring diagrams for the table/thc box would be great too.
    Ryan
    Jul 2011
    I have been doing more research, but still not finding answers.
    Correction to the original post, I have a EZR1000-THC, Not a THC-1000.
    If anyone can help me with hooking up my plasma to my THC, that would be great.
    If anyone is located in MD and would be interested in helping me setup and get my machine running private message me, and we can work out a deal.
    Ryan
    Feb 2009
    102
    Hey Ryan,
    I know the situation you're currently in. I have a 4x4 ez-router and a TD Cutmaster 52 and when I received my table, it came with zero wiring instructions. Took me a few weeks and a ton of e-mails to the original manufacturer of my THC to get it all sorted out.
    Where in MD are you? I'm down in Ocean City, MD almost every weekend and will be moving to the Stevensville or Annapolis area pretty soon. In Central NJ right now, but would be willing to help you out.
    Let me know,
    Tim
    [email protected]
    Jul 2011
    So my table has been up and running well for the past few months, thanks to your guys help and specially the help from TerraWombat.
    Recently though, I lost the use of my Torch Height Control. I'm not sure how to go about diagnosing the problem. I'm not a 100% sure but I believe it stopped working when I reinstalled Mach 3. So I have a feeling that I just lost a setting somewhere
    Last night i printed out the Mach 3 Manual and went through it page by page with no fix. I took some screen shots of my settings and program run screen to see if hopefully someone can notice something wrong. From my understanding of how the THC works, I should see voltage stay about the same during a cut. because mine is inop, I see a change of about 50amps as the torch gap increase/decreases. To me this says that my sensor card is seeing the change and the computer is just not compensating and moving the z axis.
    One thing I noticed is on my program run screen is "torch on/off" is not lit up. it is either off or if i click it, it blinks green. when its blinking and i run a program, the torch moves to the first pierce, fires, then doesn't move from those coordinates.
    When running a program and watching the diagnosis screen, i get no lights on the "torch up" "torch down"
    under config > milling options, I also tried "allow torch up/down control even in not in thc mode" and that made no difference either.
    So at this point i'm not sure if im just missing a setting or if i have another problem. any help or ideas are appreciated.
    Ryan
    Jul 2011
    PLEASE HELP
    OK so I think I narrowed down my problem. but THC is still not fixed yet.
    So i'm starting to understand how this machine works more and more by going through all the manuals, forms, and videos(Mach support). At this point i have been running a program that just cuts a 6 inch line to test all my inputs diag lights etc. i have my material on a slight angle to test the THC. What I have noticed is everything up to the MP1000 seems to be working correctly (signals from plasma to sensor card to MP1000. I get a light on the MP1000 for arc good and a light for torch up when it nears the ramp up in the material.
    when in the diagnostic screen of Mach3 i do not get these lights. from my understanding, i think they should light up when they do on the MP1000. correct?
    so at this port i think there is a problem with my port and pin settings.
    The ezrouter table came with a setup cd that has a profile with what i would think would work with the MP1000 that was also provided from EZRouter. but when i look at the pinouts in the profile, compared to the MP1000 manual, I think there is a problem. I attached the manual and a list of the port/pin locations that were automatically loaded with the profile.
    The MP1000 manual says:
    THC on: port 2 pin 15
    THC up: port 2 pin 12
    THC down: port 2 pin 11
    Mach Profile settings:
    THC on: port 2 pin 8
    THC up: port 2 pin 6
    THC down: port 2 pin7
    i have tried to change these settings but now change.
    I also noticed that in the profile there are OEM trigs 13-15 that are assigned to port 2 pins 11,12, 15. Honestly i have no idea what a OEM trigger is and I figured it might interfere with the THC so i tried removing their pins. but still no THC.
    So now I am unsure what to try and I am hoping someone can check my port pins and let me know what should be done.
    Attached Thumbnails Attached Thumbnails MP1000 Pinout1.JPG   MP1000 Pinout2.JPG
    Attached Files Attached Files
  1. Fanuc OT RS232 WIRING AT MACHINE ????
    By ED209 in forum Fanuc
    Last Post: 03-02-2011, 06:57 AM
  2. Machine Setup
    By JohnJW in forum Haas Mills
    Last Post: 07-12-2010, 08:32 AM
  3. Machine Definition setup
    By jimmy996 in forum Mastercam
    Last Post: 03-25-2010, 04:12 AM
  4. Conventional Wiring Setup
    By aucran in forum Charter Oak Automation Support Forum
    Last Post: 02-26-2010, 06:22 PM
  5. machine setup
    By bigears in forum MetalWork Discussion
    Last Post: 09-09-2009, 06:46 AM
