585,992 active members*
5,178 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > B.L.M. B/40 tube bending machine
Results 1 to 14 of 14
    Nov 2004
    321
    I buy B.L.M. B/40 made in 1970 tube bending machine and during unloading on truck forklift hit control box and smash switches, fuses and cut wires so I dont know how to connect wires. I would like to modernize machine with new electronics instead fixing old system. Machine have system for setting angle which is not useful ( 12 switches for setting angle like 30+90 to get 120° ).
    I would like to use existing el. motor=hydraulic pump, hydraulic valve, hydraulic cylinders and change how to control machine with new electronics.
    I search internet and find on forums and web pages that tube bending machine use PLC system.
    I would like to set angle of bending, controling hydraulic cylinder clamping, bending, hydraulic cylinder unclamping, retracting, add tube advance and tube rotation other functions
    Does someone know about tube bending systems.
    I find some videos for reference on youtube.
    [nomedia="http://www.youtube.com/watch?v=MwRy9z0DKxI"]‪Tube bender with numerical control‬‏ - YouTube[/nomedia]
    This video showing seting angle and bending and returning swing arm to 0 angle ( Home )
    I would like to build something like this. What is electronics ( control panel on this machine with LCD screen )
    [nomedia="http://www.youtube.com/watch?v=AA_Se50eegY"]‪MAUTIN - Curvadora de tubos servoidrà¡ulica série MTH-CT-3D‬‏ - YouTube[/nomedia]
    Some picture of my machine.
    Attached Thumbnails Attached Thumbnails 000001.jpg   000002.jpg   000003.jpg   000004.jpg
    Nov 2004
    321
    Attached Thumbnails Attached Thumbnails 111113.jpg   111114.jpg   111115.jpg   111111.jpg
    Nov 2004
    321
    System for setting angle which is not useful ( 12 switches for setting angle like 30+90 to get 120° ).
    Attached Thumbnails Attached Thumbnails 222221.jpg   222222.jpg   222223.jpg   222224.jpg
    Nov 2004
    321
    Hydraulic valve
    Attached Thumbnails Attached Thumbnails 333333.jpg   333332.jpg   333331.jpg   333334.jpg
    Nov 2004
    321
    Control box
    Attached Thumbnails Attached Thumbnails 444441.jpg   444442.jpg   444443.jpg   444444.jpg
    Mar 2008
    67
    I have been designing and manufacturing rebar bender controllers for over 20 years (among many other industrial controls). I have one that works with an older style hydraulic machine (from Italy) which may have mechanical functions and operate similarly to the tube bender, and I may be able to customize one for you, though they are built to order. Where are you located?
    Here's a brief description of the controller
    Click below for a YouTube video of the controller operating a machine in test mode:
    [nomedia="http://www.youtube.com/watch?v=HDKsOvjtiy4"]‪StirrupPro Dry Test‬‏ - YouTube[/nomedia]
    and a short video of the controller operating a machine in production: [nomedia="http://www.youtube.com/watch?v=60LndU0BDaM"]‪MVI 0201‬‏ - YouTube[/nomedia]
    Frank
    24221
    I have done a similar one using a Galil stand alone motion card, this takes care of the tube feed, tube rotation and angle bending.
    But the bend is most accurate with a hyd servo valve, you can switch a regular solenoid off by encoder position co-incidence position, but it may not be as accurate.
    The minimum display can be a 2 line/keypad Maple Systems product for operator entry.
    As this one appears to be purely electro-mecanical, there may be some work to upgrade it or replicate a modern Pines bender etc.
    Al.
    Albert E.
    Apr 2005
    175
    Upgrade
    It might make it easier to decide on next step if you had the original control manual and wiring diagram, from this a contol setup could be thought about. Looking at the pictures, it seems that most funtions were controlled by hydraulics and some control over angle, the wiring diagram, would show these controls and how the old control received data.
    24221
    Quote Originally Posted by John Bennett View Post
    It appears that there is only limit switch/relay logic and set manually, no electronics?
    Al.
    Albert E.
    Nov 2004
    321
    Al_The_Man: What you suggest me to do.
    What to use from existing machine and what to change and what.
    - what Galil stand alone motion card
    - what hyd servo valve for my situation
    - what 2 line/keypad Maple Systems or other
    - what to upgrade it or replicate like modern Pines bender
    - what I need to control hydraulic cylinder on swing arm and hydraulic cylinder on the end machine
    Can you make me a list what I need
    There is 2 limit switch
    picture 1 if chain which hydraulic cylinder break up to stop move
    picture 2 when swing arm return
    24221
    I'm afraid the type of machine you have will require a complete make-over to turn it into a auto or semi automatic machine.
    To turn this present design around needs considerable work, both electro-mechanical and electronic.
    To do this from a distance is very difficult, especially if you have limited resources in the area of electrical/electronic/motion control.
    The controller I have used in the past is like ebay 290586977192
    from Galil Motion Control.
    The machine I had converted had originally been electronically controlled.
    Al.
    Albert E.
    Nov 2004
    321
    I am not afraid to work, you tell me what I need to do and I will do it.
    Can you explain me what will controller Galil DMC 1530 controling on machine, what else I need for this controller: cables, software, TERM Operator Terminal H/P or other keypad for operator entry, encoder, servo valve........Can you make me a list what I need
    To start fixing can you see pictures of el. motor=hydraulic pump and control box how originally el. motor=hydraulic pump are connected. Can you draw scheme how to connect from wall outlet to switches, fuses, contactor to motor.
    If you need more pictures or other informations just say.
    Jul 2013
    hi did you ever fix up your blm 40 if so please send photos [email protected]
    Nov 2004
    321
    Not yet, still need figure out how to connect electric parts. I will do more work next year.
  1. My company want to buy CNC Tube/Pipe bending machine
    By Zeni in forum Want To Buy...Need help!
    Last Post: 10-20-2012, 07:25 AM
  2. RFQ TUBE BENDING
    By dshowalt in forum Employment Opportunity
    Last Post: 01-17-2011, 02:36 AM
  3. RFQ: Tube Bending Parts
    By vadimvc in forum Employment Opportunity
    Last Post: 12-21-2010, 05:02 AM
  4. Tube Bending Machine Capable of 2"x4" Rectangular Tubing
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 06-27-2010, 04:47 PM
  5. Tube Bending Question
    By charger19690 in forum Bending, Forging, Extrusion...
    Last Post: 12-07-2009, 01:20 PM
