585,974 active members*
4,339 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Retract to reference point
    May 2010
    Could anybody tell me how I can get a tool to retract to a clearance position before moving to the tool change position.
    For example if I turn a 50mm Diameter I want the tool to move clear in X and then clear in Z, like
    G0 X52.
    Z3.
    X50. Z150.
    I've tried setting a reference point in the machine definition but this has no effect on the posted code.
    Apr 2006
    76
    I think you have to use a generic move. Just insert a rapid move to the point you want.
    This is how I do it in EdgeCAM. I usually just pick a point with the mouse.
    Dec 2008
    3109
    You have to set the "Ref point" in each operation that you want the tool to be at either approaching, retracting, or both
    The tool will start it's approach from the end of the last operation, not necessarily the tool change.
    it is overcome by making sure the ref points chosen are betweem the machining area and the turret index position
    OD turning or facing would be larger X than the turning stock, similarly ID turning would be to making sure the tool retract is only in the Z-axis, say Z10 absolute ( if the front face is Z0 )
    the tool is outside the part it is not going to hit when going home
    ( my only suggestion would be to break up the retraction to the index position to going X-home & then going Z-home on seperate lines, that way, you only need to concentrate on getting any & all internal ops to be correct. )
    May 2010
    Thanks Superman that's exactly what I was after, I don't know how I missed that greyed out ref points box, I must have clicked on just about everything else!
    One more question, do you or anyone else know what the post variable is for the inner dimension of the stock. I can post all the other stock dimensions.
    Apr 2010
    24
    Re: Retract to reference point
    Thanks for that! I hunted around and finally found it on the Toolpath parameters page in the lower right corner.
  1. cnc does not reach X reference point
    By justbabak in forum Uncategorised MetalWorking Machines
    Last Post: 06-11-2010, 02:26 PM
  2. Reference point shifting in a VMC
    By visu in forum Fanuc
    Last Post: 07-14-2009, 06:11 PM
  3. Replies: 4
    Last Post: 10-26-2008, 04:42 PM
  4. G30(reference point return)
    By Reg wharton in forum Daewoo/Doosan
    Last Post: 06-13-2008, 11:32 AM
  5. Return through reference point?
    By RBrandes in forum Haas Mills
    Last Post: 12-02-2005, 04:49 PM
