585,996 active members*
4,061 visitors online*
Results 1 to 6 of 6
    Aug 2005
    5
    Trouble with Everlase laser
    Bought a well used laser cutting machine with Everlase 51 laser unit. It has 6 laser tubes (two rows of three tubes, front and back mirrors and two corner mirrors). After starting the machine, most (but not necessarily all) of the tubes gradually begin to glow, and after some time tubes begin to lose the glow. I have never got a proper laser beam from the machine. Any suggestions?
    6855
    IMO what every the problem UNLESS YOU KNOW WHAT YOU ARE DOING, DON'T TOUCH A THING, you can easliy be killed, this is not somthing you should be asking just anyone, I would call a tech to service the system.
    Aug 2005
    5
    I understand that lasers can be dangerous and that I am not a trained tech, but on the other hand I have been working with lasers for over 10 years and also I have the service manuals for the machine. I would just like to get an idea of what kind of problem this might be...
    Jan 2004
    231
    how many watts is that thing? when was it made?
    Apr 2003
    42
    Second step
    Quote Originally Posted by vholvio
    It is quite possible that the equipment you pruchased was an earlier method of marking...and worked a great deal like older dot matrix printers...only with alignments of lasers instead of alignments of metal pins ...maybe. One would need more info other than a tech manual...might be spelled out in the tech manual itself, but does not speak to levels of knowledge about lasers that are absolutely required to go further.
    The URL below speaks for itself and might just be the very thing that prevents injury when experimenting with any laser, any time.
    http://www.eio.com/repairfaq/sam/lasersam.htm
    cheers!
    cheers
    Nov 2008
    12
    Everlase 51
    Hi, do you still use this Everlase 51 laser?
