585,589 active members*
2,906 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Cleaning internal burrs on manifolds
    May 2009
    33
    I am fairly new to machining hydraulic manifolds, and am having a hell of a time cleaning out all the burrs from deep crossholes, and am spending way too much time doing so. I was curious if there is a process i am not aware of that would help ease the pain of cleaning these things out...like anodizing or tumbling etc...
    Material is t6 6061 aluminum
    any input is appreciated
    Mar 2006
    2712
    Thermal deburring was what I'm fairly familiar with. We used that on aluminum and steel hydraulic valve bodies way back in the '80's.
    The parts are put in a chamber, chamber filled with mixture of gas and oxygen and ignited. Flash burns the burrs as they are "heat sinks" leaving the parent material undamaged.
    Somehow "Surftran" is in my memory for this one.
    Dick Z
    DZASTR
    Apr 2006
    3206
    Barrel or vibratory finishing, if you can't readily get into the internals with hones or other deburring tools....
    Or abrasive flow machining, where you pump an abrasive slurry through the cavities. If you've got big burrs that are resistive and have greater strength, more likely you need to re evaluate your initial machining process.
    The flash-thermal approach is good if you can get the heat right to the problem, but aluminum does suck up the heat.
    Mar 2006
    2712
    The thermal deburring worked fine on our aluminum parts. The heat flashes too fast to sink into the parts, burns up the burrs.
    The Extrude Hone works well too. May require some "tooling/fixturing" as well.
    Dick Z
    DZASTR
  1. Saburr-tooth burrs
    By cncbcncb in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-26-2009, 01:13 PM
  2. Looking for METRIC burrs and...
    By gitano in forum Want To Buy...Need help!
    Last Post: 07-23-2008, 07:39 PM
  3. High Quality Carbide Burrs
    By rjsupply in forum MetalWork Discussion
    Last Post: 03-27-2008, 06:28 PM
  4. Machinist Tools and Carbide Burrs
    By rjsupply in forum Want To Buy...Need help!
    Last Post: 03-27-2008, 06:24 PM
  5. Burrs/threads
    By pp-TG in forum MetalWork Discussion
    Last Post: 01-21-2008, 04:05 PM
