Mastercam X5 has dropped the GUI tool list maker. The replacement is meant to be active designer.
The problem is the default setup sheets are enormously fat and super slow. The information supplied in
the setup sheets is nothing short of overwhelming.
So I edited up a nice set of sheets for 3 axis milling, really fast and gives all the info I want to see.
The files contain a text file explaining where to copy the new sheets, and there's a batch file for
one click install if your installed in default places.
These setup sheets will not in any way overwrite your existing sheets. It will just add another set of sheets
to pick from called friggenmill.
The files are located here:
http://dl.dropbox.com/u/34947158/Fri...tup_sheets.rar
cheers!
MASTERCAM ZONE
