585,712 active members*
3,977 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > NM-200 - strange behavior?
    Dec 2009
    594
    I have the V1 mill with the CPU inside the CD100, and have been generally satisfied over the past 18 months. I don't do production, make small parts, and rarely have a single run over 30 minutes, and never let it run unattended. I have seen the following happen on occasion:
    I leave the machine powered up for a couple of hours, not running. When I return none of the axes respond to jogging. I restart mach3 and it's all normal.
    A couple of days ago a similar thing happened during a run. Both the spindle and all axes stopped, and none responded to mach controls (mach showed spindle active). I recorded the 3 axis settings, restarted mach, and was able to continue the program.
    Any thoughts?
    Feb 2008
    32
    Quote Originally Posted by kvom View Post
    Any thoughts?
    I have had the same issue since our NM-200 was new and if I can ever get everything else running for more then an hour at a time I'll figure the freezing out. I think it's a PC problem, as soon as I get the new servo's, drivers, breakout board and power supply installed (yes out with the Novakoned junk and in with some electronics that work), I'll pull the pc off my lathe and see if that cures the freeze up.
    Ray
  1. NM-200 - strange behavior?
    By kvom in forum Novakon
    Last Post: 05-24-2011, 02:28 PM
  2. Strange Behavior.
    By riveracnc in forum Mach Software (ArtSoft software)
    Last Post: 11-29-2008, 01:54 AM
  3. Milltronics strange behavior
    By KBHone in forum Milltronics
    Last Post: 12-10-2007, 12:00 AM
  4. Strange circle behavior, 151B control
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2007, 03:08 AM
  5. odd stepper behavior?
    By opusinwood in forum Stepper Motors / Drives
    Last Post: 07-05-2006, 01:30 PM
