585,737 active members*
4,509 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > G02/G03 Synchronisation problem
    Jul 2011
    I am trying to make a groove on a 340 Dia bar on a CNC lathe machine Lepond with Sinumerik 810T controller. The groove radius is 6.68mm and the sharp corner is rounded by 1.5mm radius. I use a button tool with 9.5mm (4.75radius) width. When I check the profile after machining, I found that the width of the groove is increased by around 0.25mm. But this is not uniform along the profile. I have NC program with nose radius compensated manually and without compensation generated using CAM software. Coordinates from the both method found ok. Compensation parameter like tool type and radius were entered on the machine.
    I suspect synchronisation during the circular interpolation. Is there any method to check this?
    Or is there anything should I check?
    Please help.
    Apr 2006
    3206
    Have you checked that your approach distance is enough to allow the control to initiate compensation?
    Jul 2011
    Approach is distance is enough. I have program without nose radius compensation generated from CAM software. This program also follows the same path.
    Jul 2016
    108
    Re: G02/G03 Synchronisation problem
  1. FANUC Servo motor synchronisation
    By deetech in forum Fanuc
    Last Post: 05-13-2012, 04:57 AM
  2. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  3. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  4. Error at synchronisation of contours
    By qwerty1000 in forum Mastercam
    Last Post: 09-18-2009, 04:27 PM
  5. Dual X axis motors : synchronisation?
    By erlyrisa in forum CNC Machine Related Electronics
    Last Post: 05-25-2007, 11:58 PM
