Originally Posted by
mafitch7479
If I set a tool on our VM1 manually, by going into tool settings and touching off on a part or something similar, then probing a part, shouldn't it be able to carry that setting for Z zero over to a program that's probed off a different zero?
For example, if I've got a fly cutter that I touch off on a block that's 0.470" above my fixture plate, and run it at that z-zero to face off a part (which was probed off the same block, so the machines' Z-zero is set at that same 0.470). Then, later on that same part, I probe the part at 0.430" above, and try to run the fly cutter at that new z-zero, but it runs at 0.470 instead. What am I doing wrong?
