Hello,
Havn't used dowel pins a whole lot and was wondering...
I want to prep a hole for a 5/8" dowel pin. Its going in steel. Whats a recommended drill size? Should I use a reamer? What reamer size?
I've heard that dowel pins are a standard +.0002" oversize. Is that true?
Sort of in the same way a gauge pin minus set is standardly -.0002" undersize and a gauge pin plus set is standardly +.0002" oversize.
Thanks.
