586,000 active members*
5,017 visitors online*
Page 3 of 8 12345
Results 41 to 60 of 141
  1. #41
    Jan 2007
    325
    Hey Will, what size Nema34s did you decide to go with?
    BobL.
  2. #42
    Apr 2011
    Bob,
    The (3) are 434 oz-in 2.8 A 1.8 deg step
    The z is 276 oz-in 2.8 amp
    Will
  3. #43
    Jan 2007
    325
    Thanks Will.
    I assume you're running a 48v supply with that and looking for about 200-240 in/min rapids? (just a semi-guess).
    Are you running Geko's with that?
    BobL.
  4. #44
    Apr 2011
    Bob,
    I got the STDR-4C from Jeff at Soieneris. He has all the specs on his site. Speed will depend on many factors but that would be a nice rate.
    Will
  5. #45
    Apr 2011
    Little things done yesterday and today. Have the gear boxes mounted, cross members attached and the X axis cable chain done. Have just gotten a motor moving on my desk so will do more with that next.
    Will
    [IMG][/IMG]
    [IMG][/IMG]
  6. #46
    Jan 2007
    325
    Lookin' good Will !
    That 4x4 sure looks like a nice size, if only I had room for it.
    I think I'm going to go with Keling motors, some Geko's and probably a PMDX board, but haven't ordered any of it yet.
    I'm hoping you have better luck with your SS. I'm a little surprised that board isn't more popular and therefore developed (unless I'm wrong).
    Anyhow, good luck going forward
    BobL.
  7. #47
    Jan 2007
    325
    Will,
    How solid does that Z structure seem to you. I asked Dave and he said it was pretty solid, but I don't know, the more I look at the various pictures it just seems odd with those V's. I guess I'm just to used to linear rails with bearing blocks.
    Probably just too much staring at ya'lls machines while I await 'the call'
    BobL.
  8. #48
    Apr 2011
    Bob,
    As far as I can tell right now it seams heavy enough but still don't have the correct router mount so that is not on yet. May change my mind later. The Z is not a flat plate and the way its made should give it extra support, like when you put bends in steel or whatever it becomes stronger.... time will tell.
    Will
  9. #49
    398
    Bob,
    So to give you some more info on the control Will and I have.
    Its a Gecko G540 4 axis controller. It has a 48V power supply.
    Max current per phase is 3.5A.
    I think all the stepper that both Will and I have are 2.8A. So its not running all out.
    You can get a SS that plugs into several of the PMDX board. Steve at PMDX makes nice stuff. You will like whatever you get from him. I think several of his boards support more than 4 Axis. I recall you needed 5.
    There are many SS out there. In some ways its more developed than the web site would make you believe. I understand he is working on an Ethernet version which may address what seems to be the big wart on the product. Its susceptibility to noise corrupting the USB.
    I had my buddy over who is an experienced automation electrician. He reviewed what I have done wiring wise and gave it an A plus. He has a couple of tricks we are going to try once I get my SS back. He thinks the VFD might be what breaks the camels back. I have a pretty good EMI filter on it but he had a couple of tricks we will try to prove it the VFD. Then once proved we can attack it.
    Dave
  10. #50
    398
    I had noticed some flexing in my Z. After digging around I determined that the upper V groove bearing was not adjusted properly.
    It looks much better.
    Dave
  11. #51
    Jan 2007
    325
    Dave, Yeah, those were my assumptions on the equipment. I do hope to cut mine loose on the rapids though. I'm assuming acceleration will be the actual limiting factor.
    I'm not bashing the SS, I wish I would have gotten the warm fuzzy I was looking for. I did some looking around both here and a couple of other places including their forum and the noise issue kept popping up. It also seemed answers did not come quick on their forums, even to some simple ones. Of course it could have appeared that way during the few days I was checking it. Either way, I've got a dedicated PC with 2 PPs and have never had any issues running it this way so I guess it I might as well stay with what has worked.
    If I could have used it to remote my PC I would have been all over it.
    Will, I realized the Z plate was contoured, just hope it's solid enough. Although when I HAVE to run it closer to it's full extension I won't be milling that fast and when I am running it fast I could raise the work so it doesn't need to extend that far, IF needed.
    Thanks guys, nice having you guys with these machines I can bug
    BobL.
  12. #52
    Apr 2011
    Time to post an update. Been busy doing small things on my build. Waiting for longer cables from Jeff. The Z and slave are to short and want to run them first and work back. I think my router mount is shipped. Got a fax when sleeping that is was shipped. Second time they have done that to me. Have the table for the computer make. Need to sand it and one more coat of paint. Have a place to plug in my router in and today will get wood for the shelf to place the controller on.
    Will
    Computer shelf
    [IMG][/IMG]
    Adjustable in the 8020
    [IMG][/IMG]
  13. #53
    Apr 2011
    Lazy susan on top
    [IMG][/IMG]
    Electrical for router
    [IMG][/IMG]
  14. #54
    398
    Will,
    I just love your table for the computer. I might just have to plagiarize that idea. ;-)
    I need to move the computer off my table saw.
    It is amazing how much cable that machine will eat in it's cable trays.
    Before you know it you will be cutting with it.
    Dave
  15. #55
    Apr 2011
    Been busy since my last post. I make a cabinet that fits under the stand to hold my controller and has 2 drawers for storage. Knowing the problems of the SS it has a space for a computer tower. Hope I don't need it. Added another cross member to the front of the machine to make the table stronger. The sub base is attached. Have the new router mount and that is on. Just got my wires so will work on that this afternoon.
    Will
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
  16. #56
    398
    Will,
    That is looking really good.
    I am not following why you added the cross brace. It will give you a place to screw the top down instead of bolting it. ;-)
    Good idea on room for tower :-(
    Dave
  17. #57
    Apr 2011
    Dave,
    The main reason for the cross member is to have support under X0, Y0. I was not sure if the metal one would be under that so added this to be on the safe side.
    Will
  18. #58
    Jan 2007
    325
    Will, I gotta say that is coming together REAL nice. Good job dude.
    BobL.
  19. #59
    Jan 2007
    325
    I hadn't even considered mounting my PC on the machine itself. I have it and my monitor wall mounted in the garage.
    After seeing how yours' is coming together I may have to think about that.
    Once again, looks good !
    BobL.
  20. #60
    398
    Will,
    That makes sense. I guess its all about where the center line of your spindle is with respect to the ends of the gantry plates and where you have located you cross rail.
    It will all work out.
    Since you guy have the bigger machines I imagine that you can get away form mounting the monitor to the machine. I am thinking the way my machine moves a little when rapidly accelerating and decelerating mounting a monitor might make me sea sick. ;-)
    Dave
Page 3 of 8 12345
  1. DIY CNC PLASMA GANTRY BUILD OFFER
    By rchacich in forum News Announcements
    Last Post: 10-21-2010, 03:34 PM
  2. Phife's First Build. Gantry CNC.
    By Phife in forum DIY CNC Router Table Machines
    Last Post: 01-21-2010, 08:19 PM
  3. Want to build stout gantry CNC router
    By Jrs_Farm in forum DIY CNC Router Table Machines
    Last Post: 10-23-2009, 08:37 PM
  4. First build! 3-Axis Gantry-style CNC
    By TheBakachan in forum DIY CNC Router Table Machines
    Last Post: 04-18-2009, 02:10 AM
  5. Would you help me build my Plasma Gantry?
    By Mick40 in forum Waterjet General Topics
    Last Post: 11-15-2007, 12:58 AM
