585,975 active members*
4,537 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > recommendation for turnkey 3-axis nema 42 kit?
Results 1 to 6 of 6
    Jun 2009
    16
    [Hopefully this is the right forum. Holy cow there are a lot of sub-forums!]
    I have an old wells index w/ a bandit controller that fried. It has 1600oz nema 42's, 3-axis.
    Any recommendations for a complete (ideally already assembled) kit for a retrofit? I'm hoping to rip off the electronics and old motors and bolt on new ones then go.
    Keling CNC seems to have a reasonable kit for ~$1500. The other places I've looked at are either a lot more, or seem to be based in asia, where support would be iffy.
    Larkin has a already built controller, but I think I'd need to get $2,400: Larken Stepper Motor control products
    Sep 2006
    300
    Coltz,
    Are you sure those are steppers? There is a local Wells Index one of my former employers has, and it is servo motors.
    Here is a link where we discussed it:
    http://www.cnczone.com/forums/knee_v...per_servo.html
    JAckal :cheers:
    Everything is bio-degradable, if you run over it enough times with the lawnmower.
    Jun 2009
    16
    Rick at Wells Index sent me the spec sheet and said they were steppers. However, I haven't checked by disassembling.
    In any case I was thinking of just swapping out everyhing (driver, motors, etc)
    How did your retrofit go?
    Quote Originally Posted by Jackal66 View Post
    Coltz,
    JAckal :cheers:
    Sep 2006
    300
    Coltz,
    It's going slow right now. I guess you saw where I'm doing a retro on a Hurco.
    After the Hurco is done, I'm going to try to get the Wells Index and do it.
    Keep us posted.
    JAckal:cheers:
    Jun 2009
    16
    Ha, well posting to CNCZone at 4:48 am is not going to make you go any faster
    I had my own detour tonight. Spent yesterday making a bunch of endmill and tool holders out of 4x4s. Pulled a tool holder out today (< 24 hours later) and it was covered with rust! I've spent the last couple hours cleaning rust off of 200+ endmills and a bunch of tool holders. Really sucked.
    The only good thing was that it made it easy to figure out which endmills were carbide...
    Coltz,
    Keep us posted.
    JAckal:cheers:
    Sep 2006
    300
    The clock setting is off.
    It was really around 6:50 am when I was posting.
    Get out there early, and get it over with.
    JAckal:cheers:
  1. TB6560 3 Axis 6 Wire Nema 23
    By catabolic in forum Stepper Motors / Drives
    Last Post: 07-03-2012, 04:57 PM
  2. Best turnkey CNC 3-axis Mill... (Searched...)
    By MBellRacing in forum Benchtop Machines
    Last Post: 04-14-2011, 04:00 AM
  3. Keling Nema 23 3 axis pack question
    By absolutepoker01 in forum Automation Technology Products
    Last Post: 11-10-2009, 01:22 AM
  4. New Build. Nema 23's and 3-axis Univelop Board
    By HerbalHaze in forum Stepper Motors / Drives
    Last Post: 10-06-2008, 11:00 PM
