585,748 active members*
3,500 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > steppers, digital steppers or servos??
Page 1 of 3 123
Results 1 to 20 of 42
    Jul 2011
    I've finally made up my mind on my mill to convert to CNC
    it will be an LMS 3900
    Motor...hmmm - stepper, digital steppers or servos?
    any recommendations and why's? please advise
    Richard
    Jul 2011
    hmmmm,ok...guess I will call manufacturers and be left at their mercy
    24220
    Probably one of the reasons for not much response it is often a case of personal preference and/or cost.
    It might pay to search here and other sites for explanations of the up and down side to each and make your decision based on those.
    My personal preference has always been on the side of servo's which I use exclusively, but that does not mean that steppers would not also be just as capable.
    There must be examples of users of this machine or similar out there that have used both.
    Al.
    Albert E.
    One problem is you're asking about an SX2 in the X3 forum.
    There are several threads in the benchtop foum about the lms 3900 sx2.
    A g540 package with 381 oz/in steppers is more than adequate to run the mill.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    24220
    Moved.
    Al.
    Albert E.
    Jun 2011
    Do you intend to use the stock screws or convert to ballscrews?
    Either way on a mill that size I'd use steppers and I'd probably go with a G540 just because they are so easy to set up.
    I just don't personally think the extra expense of servos is worthwhile at that size, properly setup with reasonably sized servos you shouldn't be missing steps.
    Feb 2006
    7063
    On a small machine like an SX2, there is absolutely no benefit to servos. Properly sized steppers will give you at least comparable performance, for significantly lower cost. Several of us here have X2-sized machines that will rapid at 250+ IPM, have enough power to break endmills if pushed too hard, and do not lose steps unless the operator does something stupid (like a rapid into the vise). What advantage would servos provide, other than bragging rights?
    Regards,
    Ray L.
    Dec 2006
    839
    With the factory screws or ball screws steppers will do a good job here. I do tend to find myself going for better drivers than is called for though and the digital drivers are proving to be very good performers.
    WIth that said, a G540 would give all the performance you could even think about needing. Plus it would save on money which will allow you to buy other needed tools/supplies. Plus it will be easier with steppers and a G540.
    Spending money on ballscrews would be better than going with servo's. Also tools, cutters, work holding, software, measuring equipment will all cost more than the machine plus a CNC change over. It all ways takes more than most people realize so its good to save some funds when you can.
    Jess
    Jul 2011
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Thank you for your advice Hoss...I'm asking about motor types (specifically) because of my lack of knowledge/experience. I posted here because it seems that there are more X3 builds than X2 builds and want to benefit from you guys knowledge/experience. In all actuality the X3 thread should be in your aformentioned benchtop forum as it is a benchtop machine and that way all benchtop machines could be found in one place...but that's just my common sense 2 cents
    I probably should have left out that I am getting an SX2. It wont remain an SX2...I will be making my own base, X and y axes and tables, vertical column and z axis...inspired by your Hossmachine_Cnc Conversion.
    All I'm trying to find out is the difference between the motor types and what they're better for (speed, precision,control,dependability, noise, etc...)and why.
    I will be converting to ball screws also increased x,y,z axes travel and larger tables with the possibility (large possibility) of larger t-slot bed
    Richard
    Jun 2011
    The 1c version
    Servos are a closed loop motion system, they have a feedback mechanism, so the system always knows where they are, if they can't make the commanded move, the controller can add power, or wait for them to make the move.
    Steppers have no feedback they effectively get a move 1 step signal and they move one step, if they are overloaded they miss steps and the position the software thinks they are is no longer correct.
    Steppers generally provide more torque at low RPM than Servos, so most Servo systems run with reduction belt drives.
    Steppers and stepper drivers are a lot cheaper.
    In practice with a mill the size of the X2, and with 300+oz-in steppers, you wont miss steps unless you run the mill into the endstop or provide enough force to break an endmill, so IMO at least the additional cost of servos isn't justified.
    Jul 2011
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Yea...I don't care about high IPM speed's when milling...but when moving to home position and y axis to gain easier acces/inspection of parts, general axes movement to clear parts, work holders and to do ATC's. I would like some decent speed and precision for these movements...but not so much that it causes my mill to do cart wheels off of my work bench Lol
    Richard
    Jul 2011
    Quote Originally Posted by rpovey View Post
    The 1c version
    I definitely don't want to go with belts so I guess servos are out unless I use one on z axis to handle weight of mill head and accessories/attachments (would this offset the use of counter weight's, springs, air or hydraulic pistons cylinders?) Or can steppers and servers be used in conjunction with each other?
    Jul 2011
    Thanks for your help guys...your very helpful and informative. maybe someday I'll be in the position to help someone else out. :wee:
    one thing hasn't been touched on as yet...digital steppers, or am I thinking about digital stepper driver? If there's no such thing as digital stepper motor I'm probably thinking about digital stepper drivers. If I want to run digital stepper drivers, does this have an impact on what kind of motor I use?
    Thanks, Richard
    Quote Originally Posted by sabastion View Post
    Richard
    You may have noticed that this thread has been moved to the benchtop forum, why you've had more responses.
    The X3 subforum is something new and does tend to add confusion when they do stuff like that, Taigs used to be part of the benchtop forum as well. volume of X2 conversions top the list btw.
    Oh well, you're good to go.
    The digital drivers are also something new to the forum. I've tested one and they are much smoother, faster and quieter
    than their normal counterparts using the same stepper motor and I expect them to get much more popular.
    The X2's really don't need the extra speed and the g540 has proven to be a good match for it.
    You can use whatever you want, the trick is to get a motor that is a good match for the driver you choose.
    G0704 Electronics
    You'd want a bipolar parallel amperage equal to (or under) the drivers output (3.5 amps for the g540, 3.5 amps for the 381 oz/in stepper from keling)
    and an inductance that gives a good match for max voltage.
    take the square root of the motor inductance times 32.
    keling 381 = 2.8mH which equals a voltage of 53.5, the g540 runs at 50 volts.
    Hoss
    Jul 2011
    Again,ty Hoss
    as always knowledgeable and informative
    I still think cnczone should have everything that qualifies as a benchtop machine in one benchtop forum with with like-machine type subcategories for for easier locating...ecpecially for newbies like my self and good for regulars also.
    example...
    X1 types listed by manufactrurer subcategories
    X2 types listed by manufactrurer subcategories
    X3 types listed by manufactrurer subcategories
    etc....makes finding exactly what you're looking for much easier than looking from forum to forum...again, just my common sense 2 cents worth
    Aug 2006
    289
    servos
    I just wanted to add my 2 cents here on the servos since I have been using them on my x3 for a while now. I also have steppers on my lathe and I like them as well. They are also very accurate and cheaper of course, but there are some advantages to servo's I think.
    The first thing worth mentioning is that you don't HAVE to have a belt drive system if you are using decent-sized servos.
    I am currently using a couple of Aerotech 1000D's without any belts and they are plenty powerful for the x3. I was originally using Keling servos and had to use some planetary gearheads at 3:1 in order to get the power needed for the x3. I wasn't happy with their performance though and so upgraded to the used Aerotech's I got for under $100ea off the bay. The funny thing is that the Keling's actually have a higher rating than the Aerotech's but the Aero's are clearly much more powerful.
    I'm using these on the X and Y axis and for the z axis I have a much more beefy nema34 Cleveland servo that is also direct driven although it does use a belt (but at a 1:1 ratio) so no torque conversion was needed for this axis either.
    Another bonus with servos is how quiet they are! I can just barely hear them running at all. What I hear are the ballscrews turning and the table gliding along the axis and that's about it. This is actually really nice for learning since you can clearly hear what is happening with relation to the cutter and the part (and the machine). This allows me to better diagnose what is happening during a cut so I can make effective adjustments on the fly. But, this is only the case if you dump the stock spindle motor setup because it is so crazy loud that it drowns out everything else!
    Also, there have definitely been times on the mill when I was very thankful to have the closed-loop system to make up for lost steps (usually always user error) which saved me from having to scratch my part and start over from another piece of stock due to lost steps.
    Here's some pics of the servos... if you want the specs on them then I can post them for you. Hope this helps!
    Feb 2006
    7063
    Using belt reducers with servos solves several problems:
    1) Increases torque to a usable range, and,
    2) reduces max speed to a reasonable range, and,
    3) reduces low-RPM "cogging"
    Servos are typically high-speed motors - 4000-6000 RPM is typical. With a direct-drive system, a driver or encoder failure can cause the motor to go to full speed. 6000 RPM with direct drive, with a typical 5-pitch screw translates to 1200 IPM. If you're lucky, the servo driver will fault, due to being unable to accelerate fast enough, but if not, something bad is pretty certain to happen. Even without a fault, you'll be operating over only a small portion of the motors usable RPM range - kinda like buying a 500HP V12 Ferrari, and never driving it over 25MPH.
    Lost steps is a red herring. For both steppers and servos, steps will be "lost" ONLY when the system is abused by giving it a command it is not physically capable of carrying out. Unless you have a true closed loop control, all the way back to the CNC control (Mach3 does NOT support this, EMC does, IF you have the right hardware...) servos will not save you in this case, as, in all but very minor cases, the servo driver will fault, leaving you out of sync with the CNC control, just as with steppers. Lost steps are a design problem, and/or an operator problem, period. Neither steppers nor servos will EVER lose steps when the system is properly designed, components are properly sized, and the system is operated within its capabilities. For small machines, both steppers and servos are more than capable of providing exactly the same performance, and steppers will do it for lower cost (neglecting one-of-a-kind "bargains" on components).
    Regards,
    Ray L.
    Jul 2011
    Thanks guys...
    I realize for my first time mill/CNC I should do things as simply and easily as possible since I will be on a steep learning curve, that being said...
    I have some more questions/concerns on stepper motors/drivers and servos. Taking into consideration that this is my first mill and first cnc conversion (=virgin newbie). I am leaning heavily on doing Hoss' X2 conversion but have some concerns that may dictate changing some things up. One constant is that I will be using Mach3 V24 or newer.
    I will not be using belts (something to fail too easily ie...swarf cuts, tension and wear)
    Questions/concerns
    1. I have noticed in some videos that there is a noise...akin to a bunch of huge industrial old fashioned dot matrix printers running at the same time (extremely annoying/distracting). Is this the sound of stepper motors?
    2. I have seen in some pictures that it looks like servos require the use of brushes (more noise and wear)...is this true? I haven't noticed this with stepper motors
    3. The number of wires per motor; 4,6,8 wires...disregard the difficulty of properly wiring them up and connecting them to components. Putting more emphasis on control, accuracy, reliability/dependability, additional options/expandability and position location, data/signal receiving and sending (communication with components, Mach3, cad/cam and control panel) additional options/expandability and position location.
    Richard
    Nov 2009
    4415
    Thanks guys...
    Questions/concerns
    To some of us this is singing! I love it and it sounds like music. Typical of a stepper.
    Steppers have no brushes and are extremely durable when crashed. No damage will happen to the stepper itself.
    Positioning will be accurate regardless of the quantity of wires a stepper might have. Speed and or torque will change in the way it is wired and or how much current the driver can output.
    The durability of these components will keep you busy for quite a while before needing service. The servo stepper battle has been argued many times before. I do know that until steppers became available very few of us had any cnc equipment in our houses/garages. Now backyard projects have extremely high standards. As mentioned before the CAD or process will be the fault more likely than a machine limitation. You can trash parts and tooling on a big, fast accurate machine too.
    Richard
    :banana:
    Feb 2006
    7063
    Thanks guys...
    Questions/concerns
    Richard
    I think you're kinda picking the fly poop out of the pepper here.... What is or is not a pleasant noise is a matter of personal opinion. I have a stepper machine (X2), and a servo machine (knee mill), and I like the sound of both - neither is preferable, they're just different. In any case, when cutting the sound of the tool will completely swamp the sound of the drive motors. And one most small benchtop machines, especially the X2, the spindle motor is absolutely deafening.
    Reliability of belts and brushes is about the LAST thing you should be worrying about. They will be about the most reliable parts of any machine you'll build. You'd have to use the machine for many, many, many years for either to approach the point of needing replacement, and both are cheap and easy to replace.
    Regards,
    Ray L.
Page 1 of 3 123
  1. Do you use steppers or servos ?????
    By KEYTEEM in forum Polls
    Last Post: 07-05-2016, 12:49 PM
  2. steppers or servos
    By cncfoam in forum Gecko Drives
    Last Post: 06-14-2010, 05:12 PM
  3. steppers vs servos
    By accuracymark in forum Benchtop Machines
    Last Post: 01-18-2009, 01:04 PM
  4. Servos vs Steppers?
    By ZenOrbit in forum Canadian Club House
    Last Post: 02-06-2008, 02:20 AM
  5. Steppers and Servos...
    By ger21 in forum FAQ of DIY CNC Machine Building
    Last Post: 02-24-2006, 04:45 AM
