585,949 active members*
4,131 visitors online*
    May 2006
    803
    Strat 11 hole standard pickguard
    Is there a standard drawing for a genuine American Standard Strat 11 mounting holes pickguard for interchangeability purposes ?
    I have a genuine Fender pickguard in hand and will digitize (if necessary).
    I do not wish to drill multiple holes nor fill and re-drill.
    I am working with these two files.
    http://members.cox.net/bostosh5/Pick...imensioned.dxf
    http://members.cox.net/bostosh5/StratBP2201.jpg
    Thanks in advance
    Been doing this too long
    May 2006
    803
    Now Dimensioned
    Can anyone confirm these dimensions?
    http://members.cox.net/bostosh1/PICK...DIMENSIONS.DWG
    I wish to use a standard interchangeable pickguard/mounting plate.i
    I just do not wish to place bad hole locations.
    May 2006
    803
    after many question of the experts and searching, I just went ahead and guessed (digitized with Microscribe G2) at it.
    There must not be interchangeable parts for this pickguard.
    I am used to having parts interchange as on autos.
    Is this normal in the instrument construction world?
    CAD data available for your critique.
    May 2004
    4519
    Your digitization and model are easy enough to confirm by measuring a sample center-hole to center-hole across the piece to several locations.
  1. Stratocaster Pickguard
    By hh73 in forum Musical Instrument Design and Construction
    Last Post: 05-13-2019, 05:54 AM
  2. Let's Build a Strat
    By gregmary in forum Musical Instrument Design and Construction
    Last Post: 11-28-2016, 11:38 AM
  3. Strat .dxf files
    By chickenhawke in forum Musical Instrument Design and Construction
    Last Post: 02-13-2016, 09:40 AM
  4. Strat/Jem Blueprints...
    By CyborgCNC in forum Musical Instrument Design and Construction
    Last Post: 09-16-2009, 09:11 PM
