VF-4 Control computer repeating characters
Haas VF-4, New in 99, aircraft and electronic parts.
During operation a line of characters (in this case, the letter e) begins to appear at the bottom of the CRT display. There is no common factor as to when they begin to appear (checked temp, voltage, on time, load factors, etc) and they go away once the machine has been shut off for ten minutes or so.
Called Haas, and it seems to be a common problem that is easily solved by sending in the computer and a pile of cash and getting a replacement unit. Being cheap, I'd like to avoid sending them $1,500.00+ if the fix is something as simple as a cold solder joint on the mother board.
Anybody have a clue what might be causing this "common problem?"
Ahead of the leading edge
