585,591 active members*
2,575 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    May 2011
    Do you have to shunt a timer?
    I have seen what Capacitors and resistors connected to ice cube relays. I was told it was to prevent damage to the PLC because of the reverse voltage spike that can occur when a coil de-energizes and the magnetic field collapses. I have 24VDC timer that which the coil will be energized by a Allen Bradley Photo Sensor. The output contacts will be going to a light stack. Al 24VDC.
    Does the timer need to be shunted?
    Feb 2009
    6028
    Is it a timer relay? Most of the new stuff has led's on them, those are just a diode.
    May 2011
    Quote Originally Posted by underthetire View Post
    Yes it does have LED on it. And its a new one. I also cant figure out how this crappy thing is supposed to be wired it came with no documentation and the terminals are not numbered. It only has A1 and A2, which I hooked up A1 to +24VDC and A2 to -24VDC and it causes my PSU to cut on and off. The attached PDF is all I can find on it. Can you please help?
    Attached Files Attached Files
    Feb 2009
    6028
    I didn't see anything on there that would help. I'm on my iPad though, so maybe I just don't see it. Usually they are labeled on the side of the relay. I hate those btw, a1 and a2 you would thinknshould be the coils, but they are not. Your shorting out the ps.
    May 2011
    Yeah nothing is labeled. And it said it is a on-delay(On-Delay-Make).
    What is a On-Delay-make timer? I think I read its resetting by itself?
    If the timer is set to 10secs. My PSU is fine untill 10 secs then it shorts out. Same with every setting. I dont understand this freaking thing.
    May 2011
    Okay so if I have to shunt a relay or if I wanted to shunt this timer just to be safe,how would I do it. I know you can use various components but what is the easiest and how do I figure out what value of a cap,resistor ect. to use?
    And its just a matter of connecting 1 point of the cap to the + side of the coil and the - side of the capacitor to the -24VDC side of the timer coil,right? Of course getting the Capacitors polarity right.
    24220
    You only use r/c snubber if the relay power is AC, a BEMF diode if DC.
    That link appears to show a SS timer that has an internal activated relay so it should be taken care of internally?
    Also, if using a PLC, what is the reason for using an external timer?
    Even the simplest of PLC's have internal timers and counters?
    Al.
    Albert E.
    May 2011
    Al.
    Because we do not have the cable or software to change the program. It is a proface also, and Im only familiar with Allen Bradley PLCs. And finally it would void the warranty if we mess with the PLC. The manufacturer would charge us $4000.00 to do what I am trying to doing for under $300.00
    But could you tell me what rating of a BEMF diode I would need? I ask because I may be using a D/C ice cube relay either on this project or another. And how do you connect the diode to the coil? Im pretty sure I know this I just want to make certain.
    24220
    A 1N4005 or 1N4007 would be ample.
    The positive band on the diode, connects to the positive most terminal on the relay coil.
    See bottom of page.
    http://www.electronics-project-design.com/diodes.html
    What make of PLC is it?
    Al.
    Albert E.
    Sep 2010
    1765
    24vdc coil meANS a 100v rated diode is fine. 1 amp good. 1n4003, 1n4004, etc.
    +24vdc --------coil-------- common
    +24vdc --------|<--------- common
    10-4?
    May 2011
    Why can I not find anywhere that sells a allen bradely timer like these style but for mins instead of only 10 secs?
    Can you only buy allen bradley stuff straight from rockwell or what?
    The only timers I can find like this are solid state ones that you have to wire in series with your load and I need the N.O. contacts to be on a wjhole seperate circuit.
    I need this slim style and it does have to be allen bradely but I prefer a timer relay that doesnt have to be shunted and it has to be for 24VDC.
    Can someone help?
    24220
    Something in this range maybe?
    http://www.crouzet.com/english/catal...r-88865305.pdf
    It looks as though it is the same line as before, but maybe better choices?
    Al.
    Albert E.
    May 2011
    Al.
    Yes thankyou.
    May 2011
    Al.
    Do you have any recomendations as far as companies to get these from with a decent inventory and fair prices?
    24220
    DigiKey stock them.
    Al.
    Albert E.
    May 2011
    Thankx for all your help Al. I know this is unrelated but do you know a good site to get a 3 position 24vdc pnuematic valve? Someone said something about "Erby" I dont kjnow what that is and didnt have time to clarify. But they said they sell allen bradley stuff.
    24220
    Quote Originally Posted by Skiroy View Post
    Would that be Ebay.
    Check out if you have a local Mac valve rep. they have all kinds very cheap, not worth buying off ebay.
    Al.
    Albert E.
    May 2011
    Hey Al. I have a bender that has a PLC in it and I was told by the manufacturer I can splice into one of the input switches(PLC inputs), to trigger a timer relay. But they said the timer relay's coil has to be low amperage load. Im waiting to find out a rating value but could you tell me where in the documentation attached, tells me the current draw of the timer's coil? Im looking at the TAR1 but I beleive all the specs are the same for all the timers.
    24220
    It states .6w at 24v. It also say external power can be supplied?
    I find the details on the unit a bit vague, it would be nice to have one on hand to discover
    more details of the operation?
    Al.
    Albert E.
    May 2011
    Al.
    So if we went off of the .6w that would mean 25Ma,correct? You know something about these timers I dont understand?
    I had a 3 wire swicth. Standard N.O. PNP and I wire one side of the timers coil to to -24VDC and the other side to the Switches signal wire,so when the switch was triggered it would energize the coil.
    It would not work this way. The switch LED went on but very dim and would not get the coil to energized. I had to use a 2 wire switch and it worked fine.
    But when I used the same exact 3 wire switch and wiring with a Allenbradley timer. It worked fine.
    I emailed the manufacturer but their support sucks.
Page 1 of 2 12
  1. AMC B100A40AC and shunt
    By Karl_T in forum Servo Motors / Drives
    Last Post: 06-07-2011, 08:30 PM
  2. Shunt circuit
    By fahque99 in forum CNC Machine Related Electronics
    Last Post: 08-05-2009, 05:54 AM
  3. CNC First timer, a little help?
    By TheMobster in forum DIY CNC Router Table Machines
    Last Post: 06-18-2009, 05:41 AM
  4. V21 first timer
    By mmachining in forum BobCad-Cam
    Last Post: 07-10-2007, 11:36 AM
  5. R Shunt Burn
    By wanchai101 in forum Servo Motors / Drives
    Last Post: 03-26-2007, 04:20 PM
