I have a problem creating drilling operation for the part you can see on the image:
There are many holes on the circumference and I don't know how to define the operations. What I managed to achieve is to define all the local coordinates for each row of holes (I assumed that if there are 36 holes on the circumference then I'll need 18 of them) and then used the tool to find holes on the given coordinates, that worked, but there must be easier way.
I assume that there has to be a function to rotate the part. Then I could define only one set of cooridnates, drill and then rotate the part for set amount of degrees, drill again and so on untill all holes are made. Any ideas?
