Any on know the frequency settings for the 1100, low and high output for the new vfd. with the 1.5 hp motor
Thank's Phil
Hi Phil and Woffler, do you have the correct Paramaters for the VFD (series2 commander sk)?
If it's not to much of a pain can you please post them below - I'm having issues with the parameters on my one and I want to check them against a working set.
Thanks guys it would be mighty appeciated..
There appears to be as many as 80 user defined parameters and I currently don't know how to read them. If you want me to take the trouble to find out how to read them, note them down and then type them into an email you will need to be much more explicit as to which ones you actually need.
I am happy to read off the odd couple of parameters to enable you to solve a specific problem. However, with all due respect to Tormach, I would not be happy to read off the whole list of parameters.
Phil
I own a series II and here's what my VFD reads in the high belt setting
250 rpms - *Fr 6.6
3100 rpm - *Fr 89.0
5140 rpm - *Fr 144.4/144.5*
Could you give us a hint as to what the problem is so we can narrow it down and help you solve the setting problem. As Phil said there are way to many settings and ours may differ from yours and you particular machine.
