hi all,
i'm trying to cut out the parrot beak scollop from a pipe "T", (for want of a better description)
50mm dia with a 30mm hole thru the guts using a 16mm ball nose end mill
i can get a surface fin parallel at 90deg for a fin pass
but i just karnt get a decent roughing pass, what should i be using?
can start/plunge in the center due to the hole
file is in X5
any ideas?
thanks
alan
