584,861 active members*
4,827 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil x5 linear guide type?Please help.
    Mar 2009
    39
    I hope a syil X5 owner will be kind enough to satisfy my curiosity as to the linear
    guides used in there machines.It looks to be the smallest machine available with
    linear bearings,apart from the hm-070x.I am trying to find my way around the linear guide
    specifications and design formula and I hope knowing what a commercial designer is using and a
    bit of "reverse engineering" might give a benchmark to compare with.I am sure commercial
    manufacturers don't over design,so reference to a commercially designed machine is the best
    starting point.
    I know they use Hiwin guides .The m420l (which "looks like" the syil x7) spec sheet
    says it has 20mm rails on the x and y and 25mm on the z.The novakon nm-200 (similar to syil
    x6)according to another member on this forum has hgh-25ca bearings on the z.A model number
    would be great, a measurement of the rails width,spacing and truck length on each axis
    would be helpful to.Also from the pictures it appears they only have 2 securing
    screws/truck is that correct?
    Thank you.Robert.
    Apr 2006
    844
    i can show you my x7,and x6 linear,or x6 standard model linear tomorrow,by pic,if you have emails address for me will be better
    sent to my address [email protected]
    Direction,Commitment,Follow through
  1. PBC Linear Provides Upgraded Linear Guide Parts to Bay Area Transit
    By Pacific Bearing in forum News Announcements
    Last Post: 08-10-2010, 10:42 PM
  2. How much for HM-145X with linear guide???
    By diylife.com.tw in forum News Announcements
    Last Post: 07-28-2010, 10:27 PM
  3. Linear guide resistance...
    By SatanKlawz in forum DIY CNC Router Table Machines
    Last Post: 06-06-2010, 06:16 AM
  4. Choise the right linear guide
    By Cardedon in forum DIY CNC Router Table Machines
    Last Post: 03-31-2008, 07:56 AM
  5. Fuse And Linear Guide
    By Alex S.A in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2007, 11:48 PM
